Old 24th March 2003, 05:48 AM   #11
Tobey is offline Tobey  United States
Rick this is an interesting idea. It's been a while since I've built anything, but what brings me here is an interest in building a nice amp for my PC speakers. In this thread I was told about this amp using the LM3876. That thread also has the most difficult design that I ever built, I am by far not an engineer. I repaired consumer electronics for quite a few years, so I have a very good understanding in theory, but I have no formal training in design. I haven't looked into building anything in years, and to be honest I'm suprised in the amount of info found on the net. I've only been on the net since around 1996. Newbie I am
I was thinking about using the LM3886 for the sub woofer, the LM3876 to drive the five inch mid/woofers and possibly the LM1875 to drive the tweeters. The tweeters might need the LM3876 in order to "keep up" with mids sort of speak. Also I was thinking about using one of the crossovers from this page.
Maybe if the design was done is a modular fashion people could choose the amount of channels that they need, such as 2.1, 4.1, 5.1 and so on. With a choice of different power supplies. It would also need to have the ability to change crossover frequencies easily, since everybody isn't going to be using the same drivers. The link that Nisbeth posted has a nice, compact circuit board already designed for the IC which can be downloaded HERE.
I would like to build one if it was built with fairly standard components. I don't have the money or desire to build an amp with $20 resistors or $200 capacitors, unless needed, to be honest. I've just started looking in to building this amp this week, I still have a lot more research to do, but I will be building one soon. National Semiconductor has tons of info on these IC's and design parameters, you can even get free samples.
Old 24th March 2003, 10:19 PM   #12
Default DA 7294 may be better
I think this will be a while before it gets wings. Most are interested in just two channels.
When I get time, I'm going to do a couple of versions with two channels, then move on.
My reading of the threads suggest that the TDA 7294 may be a better and/ or more powerful chip.
Richard
Old 25th March 2003, 08:08 AM   #13
Matttcattt's Avatar
have you seen this? post #460 it and the following posts show JordanG's PCB design.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 25th March 2003, 07:55 PM   #14
Originally posted by Matttcattt
.......have you seen this?......
I've been slowly but surely getting through that thread, but it's going to take a while to get throught that novel.
Old 29th March 2003, 06:54 PM   #15
Question PCB
Matttcattt, thanks.
I usually print off threads (in printable version, without graphics) & read quickly offline: I had missed that.
I’ll go check it.
Did you think his design could be bettered?
multi channel t amp kendt Class D 2 4th April 2009 12:12 PM
Multi-purpose Power Amplifier domtw Chip Amps 22 23rd March 2009 03:18 PM
Multi-purpose tube amp (line and guitar inputs) smsmonster Tubes / Valves 28 20th May 2006 01:12 AM
multi-channel AMP? JAZZ2250 Solid State 1 15th September 2002 10:10 AM
Page generated in 0.10292 seconds (70.10% PHP - 29.90% MySQL) with 10 queries
