| Chip Amps Amplifiers based on integrated circuits |
Can anybody help me understand the pro's & con's of the following 2 topologies for additional current output? The attached figure shows a second power opamp configured as a current booster on the top, and a second opamp configured in parallel in the bottom. The opamp is unity gain stable. TIA
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
The bottom setup is more "uniform" by design than the top (true parallelism), which could be an advantage, besides the fact that the opamps need neither be unity gain stable nor have a big input common mode range. The top circuit is more flexible, since the master amp can be hooked up in variety of ways without the need to exactly double controls and/or component values, including the option of closing the feedback loop after the load-sharing resistors.
See Apex-AN26 Parallel Connection For perfomance audio I'd be more inclined to use the true parallel approach, it's also quite nice to bias the amps into a bigger class A region (but that can by done with the other setup, too) - Klaus |
| Booster Amp for low powered SET | eeyore | Tubes / Valves | 23 | 26th October 2008 12:05 AM |
| Booster amp | Marty99 | Solid State | 1 | 20th September 2008 01:41 PM |
| Class D Booster Amp? | IceBadger | Class D | 0 | 6th March 2008 12:07 PM |
| FM booster | MaXiZ | Everything Else | 2 | 19th December 2006 06:01 AM |
| TV booster | Cephas | Everything Else | 1 | 1st May 2002 03:45 PM |
| Page generated in 0.06509 seconds (70.93% PHP - 29.07% MySQL) with 11 queries |
