How long will a LM3886 drive???
Old 10th July 2008, 03:08 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Question How long will a LM3886 drive???
Lets say a LM3886 NIGC is used to drive a pair of long running cable to a speaker,then what's the max length before things run into trouble???
Old 10th July 2008, 04:29 AM   #2
gni is offline gni  United States
gni's Avatar
There is going to be power loss in the resistance of the conductor.
There is going to be loss of control over the cone movement.
Old 10th July 2008, 04:32 AM   #3
es44 is offline es44  Denmark
es44's Avatar
I guess it depends on the square of the cable. The "fatter" the cable, the longer the distance.
Old 10th July 2008, 07:00 AM   #4
eketehe is offline eketehe  Indonesia
eketehe's Avatar
How long you need?
Ps: its not ok to separate l/r chanel too long,no stage,just 2 independent sound.
Old 10th July 2008, 07:09 AM   #5
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
This depends on the setup of the output circuitry on the amplifier.
If you have no Zobel network and/or no decoupling inductor, you may run into oscillation as the speaker leads get longer.
The inductor in series (often in parallel with a resistor about 10ohms) that you see in many SS amplifiers is there to decouple the speaker lead capacitance from the feedback circuit to prevent oscillation.
The Zobel network helps greatly in this respect and in some others as well.
As long as the output filter is set up properly, you can drive very long cables without any trouble. The only problem you begin to run into is power loss, but it takes extremely long cabling before that is noticeable.
Old 10th July 2008, 07:23 AM   #6
YFW is offline YFW  United States
Account Disabled
Theoretically,the lengh or impedance of speaker wire should be as short as possible to prevent power loss or oscillation.
I have tried 30m before and work fine.
Old 10th July 2008, 08:59 AM   #7
fit the power amp near the speaker and use long interconnects.
regards Andrew T.
Old 13th July 2008, 07:24 PM   #8
east electronics is offline east electronics  Greece
east electronics's Avatar
Default OR USE ....
100 VOLT TECHNOLOGY then ...your speakers will go kilometers away if needed
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
How long will a LM3886 drive???Hide this!Advertise here!
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 08:31 PM
long cable line drive navin Tubes / Valves 40 29th December 2005 04:29 PM
Dedicated lm3886 to drive a sub? rs1026 Chip Amps 0 1st December 2004 08:14 AM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 11:53 PM
Orions and strange lm3886 behavior - LONG ray_jay Chip Amps 7 28th October 2003 12:04 PM
