| Chip Amps Amplifiers based on integrated circuits |
Hi all, a quick question, right as it says on the tin: I want to build the PIMETA headphone amp, but the cost of BUF634 is far too high for the build to be economical, and I'm unconvinced that the simpler alternatives like the Sijosae discrete mini-buffer deliver enough current to make them worth having at all.
My first thought was the OPA551, but I'm told that the low bandwidth will likely cause oscillation when it's inside the feedback loop of OPA2227. So, my second thought: LMH6642. Since pin 1 on LMH6642 is unused, and pin 2 on BUF634 is unused, it seems to me that I should be able to leave the bandwidth setting circuitry in place for the BUF634, and add a short between pins 6 and 2 (that is, between OUT and -IN on the LMH6642), and still be able to use each interchangeably. Of course, I'll need an SOIC to DIP converter board, but that's easy enough. So, would it work? Would it work well? Thanks for your advice! |
#2 |
Surely somebody out there knows something about using this opamp?
#3 |
For anyone who happens to find this and be interested (since this thread, despite its emptiness, now tops the google results for "LH6642 buffer"), there is some discussion unfolding over at headwize: http://headwize.com/ubb/showpage.php?fnum=3&tid=7437
| Best buffer for PIMETA? | slowpogo | Chip Amps | 41 | 26th November 2010 06:11 AM |
| Debugging a PIMETA headphone amp | Atilla | Headphone Systems | 3 | 23rd April 2009 05:12 PM |
| [help] pimeta ground buffer heating up | jchanhm | Chip Amps | 0 | 6th June 2007 04:38 AM |
| Diamond buffer in PIMETA | slowpogo | Chip Amps | 3 | 19th April 2007 05:58 AM |
| Just how good is the PIMETA? | slowpogo | Solid State | 3 | 8th March 2007 03:40 PM |
| Page generated in 0.09619 seconds (63.67% PHP - 36.33% MySQL) with 10 queries |
