Old 5th July 2008, 08:54 AM   #1
Dino-Indo's Avatar
Question LM3886 and DPDT switch
Dear friends,
Would appreciate your kind help...
I was trying to add a 3.5mm Stereo RCA socket to my gainclone LM3886, providing her with 2 options of signal inputs, i.e. from my Non OS DAC and another one from iPod or MP3 player.
Was trying to apply a DPDT switch with the connection as per attached picture... strangely, only left channel sings... right channel just silent!
Am I connecting it wrong?
File Type: gif dpdt-gainclone input selector (dino).gif (8.7 KB, 289 views)
Old 5th July 2008, 11:51 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Sounds like you have a short somewhere on the right channel. Your wiring on the switch looks OK to me.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th July 2008, 03:41 PM   #3
e_fortier's Avatar
Looks like a cold solder on the switch, if both source do not work check the right channel connection on the switch (middle contact) or simply bypass the switch with a alligator clip to see if the switch is the problem. Also make sure the gnd for all 4 inputs are tied together since they do not pass through the switch.
Your wiring circuit is OK.
Eric
Old 5th July 2008, 07:18 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Possibly the 3.5mm jack is on the case metal, and you by mistake used the ground lug for one channel? It *is* a stereo-3.5mm jack, right? Three solder lugs?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 6th July 2008, 04:53 AM   #5
Dino-Indo's Avatar
Dear All!!
Many thanks for your kind help!!
Yep... confirmed... I did somethin' foolish.. one of the feet of the DPDT switch was connected to other feet by a tiny loose cable!!
Probably I was just too hurry to finish the 3.5mm iPod connection with my minus 3.5 eyeglasses... haiyaah!!
Lesson learnt for me: "Tidy up Dino!!"
Hahahaha................
Again.... many thanks!!
Using a dpdt switch as on/off? haakok Parts 6 3rd May 2009 05:55 PM
Looking for dpdt switch jeff5x0 Parts 2 28th February 2006 08:35 PM
Need help wiring DPDT switch Static1 Parts 4 14th October 2003 10:25 PM
dpdt attenuator amt Parts 6 14th February 2003 09:08 AM
HVDC DPDT Switch Jack Thomas Parts 4 31st July 2002 12:16 AM
Page generated in 0.08191 seconds (74.21% PHP - 25.79% MySQL) with 11 queries
