I was going to go for one toroid. Ideally I want the case to be as small as possible but I haven't found the dimensions of the Audiosector kit so not sure how big to make the case. I also want to put in some shielding around the toroid ideally. So any suggestions on internal dimensions required for the case?
There is a stock answer for this sort of question - have a look around at what others have built.
There is a chip amp photo gallery in this forum, and another one at Decibel Dungeon.
Just be aware that a 'tight' design may be more challenging in terms of preventing hum etc due to the close proximity of the transformer to the amp circuit, and the close routing of the wiring.
Yep, have an idea of how big to make it (or how small). I wanted to make it as small as the case I will build for the tube pre amp/headphone amp but now I think it doesn't matter if it is bigger than it.
Peter himself recommended 9x9x2.5" (around 23x23x6.25cm) for the internal dimensions...
m0b1liz3 said:My window of opportunity is limited so will be building the case first.
I'm not sure what that means, but building the case first will require it to be bigger than it needs to be unless you risk not fitting it all in.
Advice from first hand experience: buy the toroid before building the case or leave ample extra room. Many of them are bigger than advertised due to winding unevenness and the way the mounting plate fits. I had to cut up a mounting plate to get mine in a chassis after I thought I had 5mm to spare according to published dimensions.
This is about as small as I would think you can do.......
http://www.vikash.info/audio/tatca/images.asp
The smaller it is though the build will be much more fiddly.
John
John
I'm convinced Nuuk has saved me from stumbling at the case-making stage. I had poorly planned my layout, trying to 'finesse' my Audiosector boards into the unforseen tight spaces. After reading this timely thread, I've de-crammed. adding a case for the amp boards. The chips (and I) should breathe a bit easier.
David in SW FL
David in SW FL
I do have the advantage that I generally have drawings (dxfs) of any PCB that I design, but if I want to be sure things will fit together, I draw them in 3D.
You can do this in Autocad, but it's easier in SolidWorks.
Datasheets usually have accurate dimensions for components.
I believe some more recent PCB packages will show you a 3D view, but I haven't used one.
w
w
- Chip Amps
- How small can I make a case for a LM3875 kit?
