Old 27th June 2008, 09:55 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Question Capacitor locating question
Hi all,
A short question;
Is it important the position of the rezervoir cap on board?
Means;
In this PCB layout, do you think the places for CSN and CSN1 are suitable? Why I ask that? Because if you look closer, CSN is more closer to left side transistors while CSN1 is on right side.
What can you say about that?
PS: I have a 22000uF capacitor bank per rail before this board..
Best regards,
Ozgur
Old 27th June 2008, 12:01 PM   #2
jackinnj's Avatar
When using the LM4702/LMExxxx try to attain as much symmetry as possible -- the supply lines should be decoupled as close to the power pins of the driver chip as possible, and don't bother with a ground plane.
You can mount the decoupling capacitors on the bottom of the PCB -- this will give you a bit more free real estate on the top of the board. It's only important to have easy access to the potentiometers for bias adjustment.
Old 27th June 2008, 12:48 PM   #3
Dxvideo's Avatar
Hmmm...
I can cancel the ground plane, thats not a problem.
However in this positioning, do you think the power lines are not enoughly close to the LM4702s power pins?
In fact I was worrying about the output transistors, that theyre not enoughly close to power input points..
Thats strange, because I did not declare the circuits driver chip! And if you could have a correct guess about the driver IC then you will also know the other IC. Whats it doing in there?
Just for fun...
Best regards,
Ozgur
Old 27th June 2008, 01:03 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
If you have a ground it is still important how the currents flow. It's especially important that the currents from the big smoothing caps don't interfere with the signal ground currents.
/Per-Anders (my first name) or P-A as my friends call me
Old 27th June 2008, 01:32 PM   #5
Not so difficult to know the chip. It's written on the PCB on the left side.
Old 27th June 2008, 02:18 PM   #6
Dxvideo's Avatar
Ok I will cancel the ground plane and make a star ground point there. With this way, I will also split the power and signal gnds.
And as you can see in the layout, my smooting caps GND line goes to GND point fully dedicated (via wires on bottom side). So I think they will not be a problem.
Do you agree?
So, make a guess, whats the IC (Dil8) bottom of LM4702? And what for? A tip: its not a preamp or buffer!
Best regards,
Ozgur
Old 28th June 2008, 10:13 AM   #7
You see, what I mean? Much more difficult to know, if it's not written there. And I'm not such an expert for those things anyhow.
Looks like an op amp you use as DC servo. Which op amp? Have to guess. OPA2347?
Old 28th June 2008, 12:12 PM   #8
Dxvideo's Avatar
Right,
Its DC servo, but not an OPA... However youre lucky because it was also written on the left side!
Anyway,
I am working on a LM4702+SAP15+DC Servo project. I am planning to use LF412 (as National guys used for BPA200). I will inform you about the results..
Best regards,
Ozgur
Old 28th June 2008, 12:43 PM   #9
jackinnj's Avatar
Those SAP15, 16 transistors from Sanken have been replaced by the STD03N and STD03P -- the major difference being the elimination of the emitter degeneration resistor -- this resistor couldn't take the heat (so to speak). You can pull the emitter's output from the "Sense" pin and use an outboard degeneration resistor. There are still SAP transistors around, no reason not to use them as long as you are advised of this one device shortcoming.
Old 28th June 2008, 12:50 PM   #10
Dxvideo's Avatar
But in the SAP's datasheet, if you take consider the destruction point of the internal degeneration resistor then it seems enoughly strong..
But I can put an extra pinout for an external resistor. Youre right.
Best regards,
Ozgur
Marshall Mosfet LEAD 3210 blowing power fuses - help locating capacitor(s) jmilch Solid State 13 20th August 2009 05:31 AM
Another capacitor question... Dxvideo Chip Amps 11 14th February 2008 04:02 PM
Capacitor question aarsoe Parts 5 30th January 2005 09:03 PM
Dumb Question about locating groung plane julien43 Digital Source 4 10th November 2002 12:26 AM
Capacitor Question TonyW Parts 4 21st October 2002 07:39 AM
Page generated in 0.10351 seconds (84.18% PHP - 15.82% MySQL) with 10 queries
