| Chip Amps Amplifiers based on integrated circuits |
Hi, another which chip question:
I've bought a transformer of plus and minus 16Volt. Which chip should I use for my gainclone with this transformer: LM3875, LM1875 or other? |
#2 |
First, how big is the transformer?
The voltage will work with either chip. I would try both 1875 and 3875. It will only cost an extra $20 or so to test out which you like better. The transformer is usually the most expensive part. Build a couple amp modules and compare them. |
#3 |
The transformer is rated 5 Ampere
So 32 * 5 = 160VA |
#4 |
That is ok for LM1875...
#5 |
most of the chipamps will run well from a 160VA 16-0-16Vac transformer.
You could even wire up a two channel amp from this transformer.
regards Andrew T. |
#6 |
Hi jacking the thread....
So a 330Va - 2x18v is suitable with LM3886 too ? Thanks |
#7 | |
regards Andrew T. |
#8 |
Any suggestions on how to use 30-30 output trans (460VA) for 3886 or 3875? I can get these for USD $35!! besides, major outlets have a standard config of 30-30... I was planning to run several modules from such a tranni.
#9 |
I suggested 28Vac as the maximum for 3886 on moderate 8ohm speakers, but some came back saying 25Vac was a more sensible maximum.
regards Andrew T. |
#10 |
+/-42 a bit high for a chip amp, but you can add a few turns of #14 THHN and put it in series with the primary - that will drop or raise the output depending on polarity. You could add turns to the secondaries, but that's a bit tricky if they need to be well balanced.
BTW - those are some nice trafos that Tanners has. GET THEM BEFORE THEY ARE GONE. That's not a threat, it's a promise
| FS:I/V transformer for DAC CHIP | ANADIGIT | Swap Meet | 9 | 23rd January 2009 01:07 AM |
| transformer for my chip amp? | kanifee | Chip Amps | 34 | 23rd April 2008 07:46 PM |
| Stereo Chip Amp - one transformer or 2? | groyne | Chip Amps | 12 | 18th May 2004 06:22 PM |
| Page generated in 0.11390 seconds (66.89% PHP - 33.11% MySQL) with 10 queries |
