| Chip Amps Amplifiers based on integrated circuits |
Seems that I did something silly when purchasing my transformer. I seemed to have purchased a transformer rated at 35Vrms when I though it was 35Vpeak...oops. Anyways, just curious what you guys think I should to do bring down the 50Vdc I'm getting to the 35V that I want. Figure since the max the LM3886 can take is between 80 and 90 volts...100 might be a bit too much. I was thinking of just using some high value resistors to step it down, or should I suck it up and get the correct rated transformer at 25Vrms? This is my first chip amp so I figure someone may have run into the same silly mistake and have a suggestion ![]() Thanks! Blair |
#2 | |
Forget resistors... just not an option. Last resort, take some turns off the secondaries. Torroidals are very easy to do in this respect. Frank |
#3 |
How about a nice lightbulb or two...
Seriously though, dropping the necessary 15V is not a trivial matter. It can be done, using a fully regulated supply, but having tried one on a chip amp, personally, I didnt like the sound. You can also 'adjust' the voltage out of a PSU using a CRC section at input, but again, the R will get hot - hence the lamp suggestion... The primary problem is that as this is an AB amp (mainly B actually) the PSU draw is not constant. A long winded way of saying, get the other thransformers.... Owen |
#4 |
Yea, I figured the resistor thing probably wouldn't be the way to go. So I'll get the correctly rated transformer. Also random question, should I use a fuse or a circuit breaker?
Thanks for the help! Peace, Blair |
#5 |
Hi Blair,
I got a same problem, Maybe someone have knows if we can use LM338? Brgds. Eka |
#6 |
Sell it awayr or keep this one for the other projects. Then, buy the right one for GC.
This is not your last DIY project, isn't it? |
#7 |
Electrons are yellow and more is better!
2 x 28 VAC is max healthy voltage and this will create around 2 x 40 VDC at low load.
35 VAC => forget it.
/Per-Anders (my first name) or P-A as my friends call me |
#8 | |
http://www.pedjarogic.com/gc/supplies.htm and here? http://www.tcaas.btinternet.co.uk/jlhnewps.htm yes i have them from Nordic's. Brgds. Eka |
| LM3886 Power supply | jfnewell1965 | Power Supplies | 25 | 2nd June 2011 04:18 AM |
| Power supply for LM3886 | gcds | Power Supplies | 10 | 24th March 2007 07:32 AM |
| LM3886 power supply suggestions? | DrFrankenstein | Chip Amps | 7 | 7th February 2007 10:16 PM |
| LM3886 Power Supply Schematic? | newbie1 | Chip Amps | 4 | 16th January 2004 02:39 PM |
| Page generated in 0.10361 seconds (78.96% PHP - 21.04% MySQL) with 10 queries |
