| Chip Amps Amplifiers based on integrated circuits |
Ok, I've read enough, drooled over the pics and I'm going to have a go.
I have good soldering skills and fiddle around with HI FI having had a few lessons from very clever engineers at a Hi Fi shop where I worked for years part time. My understanding of electronics is limited to recognising polarity, replacing resistors, smoothing caps, transistors, wiring and stripping rebuilding - the really easy simple stuff.. I'm careful, have a big bench power supply and test meter to assist me with my anorak moments. For me to make a gainclone from scratch I'd need close up pictures of point to point as my understanding of schematics is poor. I can easily copy something but not with diagrams ! Clearly you guys are all experienced electronics hobbyists or engineers and I fall a long way behind - apologioes in advance ! Any clear close ups of what goes where would be great. Is there a better way ? Any help from patient people would be great !! Many thanks Andrew |
#2 |
#3 |
search
Carlosfm and Vikash in the chipamps section
regards Andrew T. |
#4 |
Also check dogbreath.de Simple designs with very detailed photographs and explanations and clear schematics. You could try his copy of the original gaincard.
He has even simpler designs but you have to be careful because they do not offer protection against DC offset and your speakers could be at risk if you do not know what you are doing. Regards |
#5 |
Ditto to what Puffin said
#6 |
Copying from a picture might work, but what will you learn from that.
Learning to read a schematic is your best bet. It is not difficult. A chipamp schematic is a great place to start as there are only a few components to deal with. Just some resistors and capacitors. Make sure you download the data sheet for whichever chip you use. If you get confused, google, go to the data sheet or come back here and ask. Shown is a very simple circuit for the LM1875. Only 6 components plus the chip. |
#7 |
FYI,the attached is my 3886igc connections.
..z |
#8 |
and the pdf is schematic.
..z good luck! |
#9 |
Digi,
your schematic does not match the layout. That will confuse him.
regards Andrew T. |
#10 |
i know,i have not draw the Rt,Ct.it is option.
i hope you can understand zang
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 12:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
| Page generated in 0.10088 seconds (78.05% PHP - 21.95% MySQL) with 11 queries |
