Old 17th June 2008, 09:40 PM   #1
Default LM3886 schem, feedback cap.
Hi!
In the (official and standard) schematic for the LM3886 there is an optional feedback capacitor with value 22µF. Most of the inofficial schematics write this as a polar (electrolytic) capacitor. Wouldn't this be kind of bad since it is connected to output through the feedback resistor and would see both positive and negative voltages compared to ground?
Old 17th June 2008, 11:25 PM   #2
KSTR is offline KSTR  Germany
KSTR's Avatar
In normal operation this cap (Ci on the datasheet frontpage) sees only AC little voltages (millivolts at best) accross it because its impedance at audio frequencies is low compared to the resistors. Only under a continuous DC signal with the wrong polarity applied this cap would suffer a little, although the resistors help avoid catastrophic failure (they limit the current to very low levels).
It is pefectly ok to use a polar electrolytic here when the circuit is properly designed and used.
- Klaus
Old 18th June 2008, 12:26 AM   #3
Thank you very much, that makes perfect sense!
Me and a friend are planning to build one dual channel amplifier each with this chip and I am now choosing components and designing a PCB:
Old 18th June 2008, 02:36 AM   #4
ionomolo's Avatar
Send a message via MSN to ionomolo
Default Re: LM3886 schem, feedback cap.
Originally posted by Ivarsson
Hi!
I agree with KSTR about the low signal levels at the cap, but i suggest a higher value (47uF - 100 uF) to get a better bass response. 22 uF + 1K has its corner frequency at 7.2 Hz, this seems fine but electrolytics distort near the cutoff frequencies (nothing to do with strange unmesurable effects) so it's better to place the corner at a lower value.
Old 18th June 2008, 03:34 PM   #5
KSTR's Avatar
I can back ionomolo's suggestion. Indeed, most designers choose an electrolytic cap about 5x...10x larger than the smallest meaningful design value with a "perfect" cap, say a good film type. Besides the distortion issue another reason is aging and less controlled tolerances of electrolytics. When the corner frequency is low enough, say about 1Hz, these kind of problems don't have much effect anymore.
- Klaus
Old 23rd July 2008, 11:59 AM   #6
CFT is offline CFT  Hong Kong
The design in my amp has Ci (10 uF BG N) but no Cin.
Does anyone have experience whether this configuration is better or not in terms of sonic performance than having Cin but not Ci? (I understand that there will be no DC gain if Ci is in place). Thanks!
Old 23rd July 2008, 12:59 PM   #7
miss out both to create a DC coupled amplifier. But, include a DC servo and DC detect and cutoff.
or
include both to make an AC coupled amplifier.
But, don't miss out one to make a mixed AC & DC coupled amplifier.
regards Andrew T.
The 'Ci' DC blocking cap in the LM3886 Feedback Loop speakerguy79 Chip Amps 9 29th June 2009 06:03 PM
schem for LM1875 PCB missieek Chip Amps 1 29th October 2008 09:31 PM
low value feedback resistors on LM3886 jarthel Chip Amps 10 17th October 2007 09:50 AM
LM3886 current feedback problem. pro Chip Amps 4 3rd October 2004 11:03 PM
Final LM3886 GC Schem meta Chip Amps 5 1st August 2004 10:00 AM
Page generated in 0.10373 seconds (73.58% PHP - 26.42% MySQL) with 10 queries
