Smallest I have ever seen = I have one and it orks great!
http://www.diygene.com/servlet/the-415/4-way-Motorized-Remote/Detail
This PGA23XX/CS3310 IR controller board is fairly small, but it requires a seperate board with the PGA23XX/CS3310 on it (which could be made even smaller).
http://www.tauntek.com/irvc-ir-master-for-remote-volume-control.htm
thank you for the site remote tiny control board.
but i have no clue how to connect them together with the additonal board.
and i was thinking using it with small motor from cellular vibrator motor to control the potentionmeter.
I can build the mechanical gear for the pot. but I have no idea how the electronic part .
cal
cal
Here is "the Scandinvian guy" from post #2
http://electronics.dantimax.dk/Kits/Control_boards/index.html
This board isn't specifically for a volume control, but it could be configured to power a motorized pot. It's only 5cm x 4.5cm.
http://www.apogeekits.com/ir_receiver.htm
Joined 2003
Ok, well if you need much smaller than that you're likely limited to designing it yourself with small SMT components. You can use a digital volume control IC such as a PGA2311 and a micro to remove the space taken up by the pot and motor, but if you're going to do all that work unless you really love your chassis I would say it would make more sense just to get a slightly larger chassis.
You can't squeeze one of the kits in there if you lay the pcb on it's side maybe?
- Chip Amps
- Where can I find Smallest Volume Remote Kit ??
