Old 12th June 2008, 11:44 PM   #1
Default Another Gainclone grounding problem - follow up question
Hello,
One more quick question. If you have viewed my recent thread, you know my project is a 2nd order S-K x-over, the high section feeding Gainclones, the low section, at least for now, a Carver M400? (the famous, or infamous, cube). The grounding on the GC - xover is, xover PG to case through 100ohm R in series with 100nf cap, then the case to earth gnd (green wire in 3 conductor cord). The signal gnds go to the GC SG. Now I don't know what gnding scheme is used in the Carver amp (2 prong plug).So my question is, should the shield on the interconnects between the low xover (GC SG) and the Carver amp be connected at both ends, one end (GC??), or something else?
TIA
Old 13th June 2008, 10:54 AM   #2
the signal has to flow and return.
regards Andrew T.
Old 13th June 2008, 01:18 PM   #3
Of course. I was thinking of a 2 conductor shielded cable. Sorry about that. In the future I'll make sure I think twice before posting.
Gainclone - Grounding Mareus Chip Amps 4 13th May 2009 07:22 PM
Another Gainclone grounding problem MikeFarad Chip Amps 6 9th June 2008 12:22 AM
Gainclone Grounding Scott_drake Chip Amps 10 11th February 2007 08:26 AM
Grounding problem question? excetara2 Solid State 5 10th November 2006 04:39 PM
Follow up question (16-4 Gauge Speaker Wire) FrankRoss Everything Else 0 24th December 2001 07:06 PM
Page generated in 0.06875 seconds (66.38% PHP - 33.62% MySQL) with 10 queries
