| Chip Amps Amplifiers based on integrated circuits |
According to the datasheet, the manufacture set the gain of 30dB in their recommended circuit.
Will I cause any adverse effect or any performance degardation to the Amp if I lower the gain to about 27dB? Will the amp tends to oscillate after the gain has been set to certain lower value? Intended load impedance is 8 Ohm. Supply voltage will be +/-40V, regulated. Thanks. |
#2 |
I've tried TDA7293S with 21X (~26.5dB) gain and observed no problem.
Best regards, Ozgur |
#3 |
I also tried with TDA7294 a few monthes ago. It worked very well.
#4 |
Thanks guys.
#5 |
Pa Pa Pa at the output and much noise .
#6 |
i have checked 7294 with gain setting 26 as the usual power amp.it is sound good.
there are two cases i am interest in 7294. 1,it is cheaper than nsc's overture series, 2,it is mosfet output. |
#7 | |
According to spec sheet : Quote:
/sreten.
| TDA7294. . . help! ;) | danielwritesbac | Chip Amps | 3 | 19th April 2008 06:58 AM |
| My TDA7294 Amp | panson_hk | Chip Amps | 1 | 27th June 2007 01:06 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Need help on tda7294 amp | Fossil | Chip Amps | 6 | 20th April 2005 02:53 PM |
| Tda7294 | Angel Puerto | Chip Amps | 6 | 21st August 2003 02:08 PM |
| Page generated in 0.07860 seconds (74.03% PHP - 25.97% MySQL) with 10 queries |
