| Chip Amps Amplifiers based on integrated circuits |
In general, regardless of circuit design/sonic charater, should using bigger caps, or using oversize transformer, will make an amplifier sounds more dynamic and powerful?
For example a power amp circuit recommand using 180VA transformer with 10000uF x 2 caps for each channals, so: A) 180VA transformer with 22000uF (or bigger) x 2 caps or B) 220VA (or bigger) transfomer with 10000uF x 2 caps Which config should I go for? |
#2 |
and what kind of amplifier do you propose?
regards Andrew T. |
#3 |
Let's look at this question another way. The difference in price of the two transformers you suggest is only a couple of pounds (possibly smaller where you are). So go for the larger transformer and don't even think about.
The cost of pairs of 2200uF caps, and 10,000uF caps would be less than another 20 pounds. So buy both and try them. If you are into DIY, you will always find a use for the ones that you don't use. There really is no substitute for hearing these things for yourself. An answer from God himself would only express His opinion!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
Thanks for the comments.
I am referring to a very general GC 3886 circuit, and yes, a larger transformer cost far much less then larger caps here in Hong Kong, but due to the limited of chassis space, I can only make choice for either larger transformer or larger caps. Although I have lots of spare caps in hands, but all just could only use for testing, which I will not use them in the amp finally, since all I have left is Japanese brands take out from kits I have ever order, but I always only use European brands materials, as I still will finally spend money in the end, so I would like to ask for comments, skip the testing stage for keep the spare components still new, maybe someday I can sell them to someone who like Japanese audio grade components, and target to what I should spend for. |
#5 |
test the options outside the box and then adopt the final layout inside your size/volume constraints.
regards Andrew T. |
#6 |
just to know:
if i have power supply with 4 caps (6800uF x 4) those are different brands.... what happen with it?
#7 | |
| THIS output stage. For your consideration. | MJL21193 | Solid State | 20 | 5th November 2009 05:55 PM |
| Supply wiring suggestion | jackinnj | Power Supplies | 0 | 17th November 2006 07:23 PM |
| CLCRC power supply config | jarthel | Tubes / Valves | 3 | 26th May 2006 05:52 AM |
| Correlation-Sound and Power Supply Config | fmak | Digital Source | 1 | 26th January 2006 07:13 PM |
| build consideration for Zev V4 or Aleph 3 | garfieldcat | Pass Labs | 5 | 29th August 2005 03:11 PM |
| Page generated in 0.28999 seconds (26.25% PHP - 73.75% MySQL) with 10 queries |
