Best buffer for a chipamp? - Page 3 - diyAudio
Old 27th June 2008, 06:13 AM   #21
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Originally posted by thoronx
Dxvideo , can you post your pcb of LM3875 Amp with Pedja's buffer, thx.
Do you want as PDF or the originals? (Eagle)
Best regards,
Ozgur
Old 27th June 2008, 10:32 AM   #22
thoronx is offline thoronx  Yugoslavia
thoronx's Avatar
Send a message via AIM to thoronx Send a message via MSN to thoronx Send a message via Yahoo to thoronx
I have Eagle installed, so it might be a better idea to have it in Eagle format, Thanks again.
Old 27th June 2008, 10:37 AM   #23
Dxvideo's Avatar
Enjoy it...
By the way, mine is "some" cracked 4r16 version. Hope yours can read.
Best regards,
Ozgur
Old 27th June 2008, 10:47 AM   #24
thoronx's Avatar
thanks, I will try it at home...
Old 27th June 2008, 10:52 AM   #25
Dxvideo's Avatar
Originally posted by BWRX
Now build one with the AD797 and see which one you think sounds better instead of letting everyone else decide for you.
I will...
After having a couple of AD797 of course.
Best regards,
Ozgur
Old 30th June 2008, 06:20 AM   #26
thoronx's Avatar
Dxvideo, nice eagle file, initially I can't open it, but with a little help of Eagle_LegaliZer it was a piece of cake, but I have found some unrouted nets, and I'd like to ask You once again if You can please post Your PDF version, the PCB is nice and I don't want to modify it, just to make a proto, and the pdf will be sufficient for this.
Old 30th June 2008, 07:17 AM   #27
Dxvideo's Avatar
I think you must make Ratsnets to rebuild the groundplane on the left side. But after that if you will insist on PDF files the I will send.
Good luck.
Best regards,
Ozgur
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
valve buffer with chipamp.com lm3886 juluska Chip Amps 0 12th January 2009 10:09 PM
Another first chipamp A Sanchez Chip Amps 18 4th June 2008 07:44 AM
Chipamp buffer / filter Nordic Chip Amps 14 24th August 2006 04:46 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Copyright 1999-2017 diyAudio
