| Chip Amps Amplifiers based on integrated circuits |
I am designing teh Reclock module, which accept spdif digital audio and decode to pcm and encoder it to spdif.
According to the well known audio maker, such like reclock module help reduece the jitter so that audio quality will be upgraded. Everybody agree with it? |
#2 |
Electrons are yellow and more is better!
How do you mean? Do you plan to make a blueprint copy or just the same function?
BTW: Nice stuff you have got.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
I attached the block diagram below.
I already designed the module and today I'll get the pcb. But I designed but I wasn't not sure if I can call it 'Reclock Module' or not. and How it work... If anyone need the board, then I'll give it on only charge of pcb. |
#4 |
I think saying "reclock module" is like saying "DAC" or "Amplifier" to describe the function of a device.
#5 | |
You can call it whatever you want but why not a cooler name?
#6 |
I am wondering why the file doesn't show up..
#8 |
I attach picture again again
#9 |
I finally designed Reclock Module.
It accept coaxial and optical digital audio signal, and it decode and encode. Then It output through tamura trans for coaxial, through fiber module for optical signal. When it is applied to High-End DA converter, Then it's measured dats shows that SNR and quality are advanced. But to install it inside audio intruments, then it need dc supply(about 7 volts). But we patience it for better sound . picture refer : http://www.digi-hifi.com/?pt=bv&st=l...=gallery&no=14 refer to below site(Korean Site) http://cafe.naver.com/digihobby.cafe...Farticleid=760 |
#10 | |
Could you publish these measurements? |
| Page generated in 0.09058 seconds (78.32% PHP - 21.68% MySQL) with 10 queries |
