Old 17th June 2008, 07:07 PM   #41
You used different inputs?
Old 17th June 2008, 07:36 PM   #42
Yes, i tryed with my PC and with an Ipod
Old 17th June 2008, 09:24 PM   #43
Ah, I see. But can you measure DC at the input, when you connect anything? Or can you put a capacitor in line with the input to see, if the hum goes away (Cin in the datasheet)? For the test the value doesn't matter.
Could it be that your input connections are reversed?
Old 19th June 2008, 06:29 AM   #44
will try with other Input wires, i will build another wire tomorrow, i cant figure whats wrong with this amps
Can someone tellme some values that i can measure to check if everything are OK?
Old 19th June 2008, 08:47 AM   #45
Puffin is offline Puffin  United Kingdom
Here is a simple point to point 3886 diagram. Why don't you try this. I did and it works perfectly. It is inverting
http://myweb.tiscali.co.uk/nuukspot/...lone_3886.html
Old 21st June 2008, 01:57 AM   #46
i really dont want an Point To Point amp, i want to use an PCB that works
I cant figure whats wrong will try with other components values.
Old 21st June 2008, 11:46 AM   #47
You can find many working PCBs on the web. Buy or copy any of them. If it doesn't give you the same problems, you know for sure that your PCB didn't work. Then you can still improve yours.
If you have the same problems with the PCB from the web, you know that you have to find the solution outside of the PCB.
The advantage of the point-to-point solution is that you can do the same test without any PCB. No problems with p2p means, improve your layout. Problems with p2p means, search the fault outside of your PCB.
Old 21st June 2008, 06:52 PM   #48
I CANT BELIAVE IT!!!! i get it working! both PCBs works great!!! :S
the problem was the input wire :S was in short!!!! DAMN DAMN DAMN
now i get it working and works GREAT !!!
well, now i have two design (2 pcbs), and want to optimize the components values / brand to get the best possible sound.
Hope you guys can help me on that !
will play with PSU later, now i just want to optimize the size of the PCB and the components. like i told before, i think that the new PCB are a little small, and maybe will get into troubles to solder the output wires and stuff like that.
Can someone tellme if exist some kind of guideline to build the pcbs, and if always small are better?
Old 27th June 2008, 03:08 AM   #49
wel,l now im trying to build the Deluxe version of my LM3886 Gainclone, im using 1 trafo / channel (maybe will try with two to see if something are improved.
Will use Caddock MK132 for feedback, Riken for gain setting, and for smoth my transformer will use some Panasonic Caps. Wich any can improve the amp?
Old 29th June 2008, 08:55 PM   #50
sneih is offline sneih  Indonesia
sneih's Avatar
hmmm congratulation....
please take a photo of your new GC hehehe
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 07:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 01:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
6*lm3886 Bpa Tim__x Chip Amps 1 15th August 2004 05:45 AM
Page generated in 0.12141 seconds (80.99% PHP - 19.01% MySQL) with 11 queries
