Old 31st May 2008, 01:53 PM   #1
sled108 is offline sled108  United States
sled108's Avatar
Default Cmoy Pre-Amp ground hum
This might be a real simple problem, but the threads about ground hums are many, and I've not found a simple answer so far.
What I have here is a Cmoy Pre-Amp powering a TA2024 Amp.
The problem is a ground hum increasing with volume, with no inputs connected and even on the 9V.
This I can easily remove by touching the front face plate.
Am I overlooking a basic grounding rule?
If so, can someone please tell me how to ground this properly?
Thanx...
Old 31st May 2008, 02:51 PM   #2
Minion is offline Minion  Canada
Do you have your face plate grounded?? if you don"t then that just might fix it , if you Do then I suggest maybe try removeing the ground from the face plate....
Cheers
Old 31st May 2008, 03:26 PM   #3
theAnonymous1's Avatar
Cheers
I agree, but to be more specific I would connect the ground from the face plate to the ground directly at the potentiometer.
It's interesting your using what looks like one of the small green ALPS RK097 series pots. I used one of these as a passive pre in a TA2022 amp and also had hum. The hum would disappear if I removed the pot from the front of the chassis or if I grounded the signal at the pot to the chassis. There was no hum at all before I installed the pot and the signal ground was never connected to the chassis.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 1st June 2008, 12:24 AM   #4
Zigis is offline Zigis  Latvia
I use ALPS RK097 in CMoy amps, wen I touch pot's shaft there is hum. I ground shaft and hum gone.
Solder resistor legs cutoff to pots ground and bend it to front to touch metal part of pot .
Old 2nd June 2008, 03:40 PM   #5
sled108's Avatar
I have both removed the Alps from the face plate, and grounded it and the plate to the board's ground and there was no change. The hum is still there... Maybe it's the Amp's PS....From a Canon Printer...
Next, I'll have to work up a 12v battery pack and see how that does.
Old 2nd June 2008, 04:09 PM   #6
If it goes away when you touch the front I doubt it's caused by the amps PS. There has to be some grounding problem inside the pre. Maybe a ground loop between the front and back plate?
Old 3rd June 2008, 11:57 AM   #7
sled108's Avatar
Well it seems I've found the answer to my ground hum, and it is kind of stupidly simple...
When I designed this setup, I used (2) 3-Pole 3PDT switches for the input selectors to isolate the grounds. This causes an open ground hum when the switches are both off. Switching one on to an input solves that problem.
The ground hum never exists as long as you're listening to a source.
Active ground cmoy: Help me learn PCB design TheSeekerr Chip Amps 2 23rd July 2008 09:20 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
DC filament ground and high voltage ground mikeyho Tubes / Valves 0 15th September 2005 05:52 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 3 28th February 2003 05:31 PM
Page generated in 0.08355 seconds (77.52% PHP - 22.48% MySQL) with 11 queries
