Old 27th May 2008, 10:55 PM   #1
Default Please help with polarized capacitor!
I am building this design: http://www.vikash.info/audio/p2plm3886/
The CS capacitor that I have is a polyurethane axial cap with one line on one side which means, as I understand, that it is polarized one. On the other hand the diagram assumes that a non-polarized MKT type will be used, so it does not specify which way to put it.
Is it cap + with chip + and cap - with chip - or the other way around?
Thanks very much
Antonio
Old 28th May 2008, 06:35 AM   #2
I have never seen a polarized 300pf before, but i dont know anybody else have maybe.
if it is a polarised, then + cap should to + chip. IMHO.
Old 28th May 2008, 06:54 AM   #3
It's interesting that there has been only one answer (Thanks Casiomax)
I'm sorry if my question is too obvious Or is it not?
This is the cap:
http://uk.farnell.com/jsp/search/pro...sp?SKU=9520740
There you can see the band/line towards one side of it. If the line means there is polarity, which side would be the +
The datasheet does not mention whether it is non-polar or not. I'm going to call the manufacturer later today.
Any more comments would be appreciated.
Antonio
Old 28th May 2008, 06:59 AM   #4
I beleive that was a polystyrene cap, not an electrolytics. On the schematics usually an electroytic cap will have a + marking, the 300pf does not have, so you should use a non electroytic cap.
Old 28th May 2008, 07:01 AM   #5
Send a message via AIM to DigitalJunkie
It is non-polar.
It is usually common that the "outer" foil is the one connected to the striped lead.
It was once suggested that the outer foil is connected to the lower-impedance side of the circuit,to give a sort of shielding effect.
Old 28th May 2008, 07:06 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
Polarized caps have values over 4.7 uF in general. You can find lower values but they are rather uncommon these days.
/Per-Anders (my first name) or P-A as my friends call me
Old 30th May 2008, 07:41 AM   #7
glennb is offline glennb  Australia
Originally posted by DigitalJunkie
It is non-polar. It is usually common that the "outer" foil is the one connected to the striped lead.
Correct on both counts.
Glenn.
Old 30th May 2008, 09:01 AM   #8
Thanks very much for your help. The cap is now installed and the amp is working perfectly.
By the way. Are these type of caps a good choice for audio? I read somewhere that they are but I would like to know the forum's opinion.
The reason I'm using it is just because I could not find an MKT one with the same specs to use as Cs in this schematics.
Antonio
Old 30th May 2008, 01:16 PM   #9
Its a matter of different sound IMHO. different caps have different result, what sound better to you might not be to others. but does not hurt to try different types of cap.
I dont know about others experience, but does it?
Old 30th May 2008, 01:26 PM   #10
replacing the 3u3F MKT with an electrolytic will not achieve the same thing as was intended in the PSU schematic you posted.
regards Andrew T.
Polarized to non-polar capacitor wiring mjarve Parts 8 2nd April 2012 03:27 PM
Not polarized electrolytic capacitor in power supply (LM317 LM337) ygg-it Power Supplies 5 19th October 2008 07:25 PM
Black Gate Standard Polarized or PK Mini Polarized = Rubicon YK or YXE kurtbauer Parts 1 21st August 2008 06:50 AM
Polarized Capacitor on schematic question silentblackhat Solid State 9 13th June 2006 06:08 AM
Aleph 5 DC feedback capacitor (C5) reverse polarized jwb Pass Labs 3 1st October 2003 06:20 PM
Page generated in 0.10238 seconds (84.72% PHP - 15.28% MySQL) with 10 queries
