| Chip Amps Amplifiers based on integrated circuits |
#111 | |
regards Andrew T. |
#113 |
Hello Andrew,
Providing it is certified, and even then you hear tales of "substandard" shall we say products. |
#114 | |
All of the units I've seem here (Canada) are grounded also - three pin input. Something like 20VDC output, 2 pins. |
#115 |
As I say my laptop (U.K.) has a 3 pin inlet which "Must be grounded"
#116 | |
I was refering to psu's like the one in the picture of post 105 by Juerguen Knoop. I bought them at the supermarket for $20 and, as you can see from the picture, they have a 2-pin input so there is no safety ground. I havn't encouraged anyone to "hand-disconnect" safety earth! Whether they are safe or not, well, since laptops have metal screws and jacks i belive doing a gainclone with these supplies to be as safe as plugging them into your laptop. I don't expect things bought at the supermarket to be extraordinary dangerous, but you should not touch the wires anyways. The couple i bought have the "double-insulated" symbol. |
#117 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#118 | |
Yes, i placed a pair of standard dc female jacks like the ones that laptops have on the gainclone so as i don't have to cut the wire from the psu to keep the warranty! the positive from one jack goes to the negative of the other and to 0V. I did try various models and there is a zappa one which in spite of not being safety-earthed does not have the double-insualtion logo. This was the cheapest, the smallest and also the most noisy (obviously big chokes and caps don't fit there), so i suggest to go for a better one. I set them at 20V 3.2A but they can go up to 24V 2.8A. Not the most powerful thing i've seen but they do the job very well for a beginner project. I use them in 16V 4A for my class-A experiment as i've found that finding a transformer that has that current capability with so low voltage is impossible here and shipping a weighty transformer very expensive. For "high-end" power i use "aqueduct" filtering (putting several pi-filters in series. The on-board cap should have very low impedance from 100Hz and i let the logic at the supply to take care for the bass. I've found no problem at all and the chokes i use are free as i take them from broken computer smps. I'm very happy with the results and i belive it's a nice supply for newbies both for price and safety reasons (absolutely no construction/modification of mains-wired equipment). I have no idea how these are designed but if it's done properly the current-limiting function should not present any more dissipation than normal operation so it would also be very safe for the circuit. |
#119 |
Yes, if the correct SMPS are used like you are using them, I agree, it would remove a lot of the angst (and potential pitfalls) for first-time builders!
| Beginner's Gainclone, HiFi LM1875, The Amplifier Board | danielwritesbac | Chip Amps | 84 | 15th January 2010 10:44 PM |
| Beginner's Gainclone, LM3875, The Amplifier Board | danielwritesbac | Chip Amps | 37 | 22nd May 2008 06:43 PM |
| Page generated in 0.10560 seconds (76.26% PHP - 23.74% MySQL) with 11 queries |
