NAD 5420 CDP opamps
My electronic knowledge is limited so this might be a basic question ...
The attached section of circuit diagram is one channel of the output stage of a NAD 5420 CDP.
Q202 and Q204 are both NE5532 dual opamps but as you can see Q202 is using only pins 5,6 & 7 while Q204 is using pins 1,2,3, 4 & 8.
It appears to me that only half of each of these dual opamps is being used. Is this correct?
Secondly, Q202 appears not to be using the V+ & V- power supply connections. Are they omitted by convention or if not, what's the role of this opamp?
I ask these questions because I had been planning to replace the NE5532 opamps in my CDP with a set of Burson's discrete component dual opamps but it doesn't look logical to just replace both [or all 4] of the NE5532s with 4 x dual Burson opamps.
parrot
parrot said:
Yes, there's logic behind that suggestion but the other side uses a completely separate pair and that's clear from the full circuit diagram [as well as by looking inside the box :)].
parrot
Really? Can you post a complete schematic of all the audio stages and/or the PCB track layout. I can't believe that half of dual opamp part would be wasted in a commercial design, when a single opamp part could be used.
Administrator
Joined 2007
Going crosseyed looking at that :xeye: . They are 5532,s not 5534 in the player. Pin 5 does not look connected on the layout.
Edit, If they are 5532 then there are 8 individual OpAmps in there, the filter for the player shows 4. So how are they connected. The image is not really clear enough.
