Old 2nd June 2008, 06:45 AM   #51
Mooly's Avatar
Look here www.burr-brown.com The link will redirect you to Texas Instruments who now own Burr Brown. In the top right box under part number enter opa2604. When that page loads click on opa2604 under the part numbers offered. You can now download the pdf data sheet for this I/C . The applications given might help you make sense of it all more, and it describes the IC in detail. The TL072 is a Texas part, check that out as well, the LMxxxx are National Semiconductor.
Old 2nd June 2008, 06:47 AM   #52
parrot is offline parrot  Australia
ok ... that all makes sense.
I've looked at opamps in Wiki but I'll have a look at Butterworth etc.
Some of this is way above my head but at this point it seems that trying a few different opamps will be safe and interesting and that's the goal.
So ... thanks again Karl. I'll order a few opamps, solder in some sockets for testing and see how it goes [in the middle of building a sub at the moment so I'm a bit ahead of myself here but it gives me time to think about options].
parrot
Old 2nd June 2008, 06:49 AM   #53
aaaugh,
typing while you posted but yes, I'll be checking that one out too.
parrot
Old 2nd June 2008, 06:59 AM   #54
Mooly's Avatar
I would be interested to know what YOU think of the different I/C 's . The OPA2604 (and 604) certainly do it for me. They made my MicroMega Stage 2 really sing. I can't fault them. I also used them in the preamp section of my latest amp build.
As I said earlier though, try different ones and do try a couple of 4558's, they cost peanuts, they are as bad as it comes ( for audio), and it's just really interesting to see how far we have come ( or not ! ).
It's a bit like washing powders. . In the 80's it seemed that a new improved version was advertised every other week, and this went on for years, so by definition, the first ones must have been spectacularly bad.
Old 2nd June 2008, 07:07 AM   #55
LOL ... gotta say the idea of trying something "as bad as it comes" has a certain quirky appeal.
I'm looking forward to doing a bit of swapping. Having replaced the output caps with wire, it seems the longest part of any process is taking the box apart though with the sockets in place that won't be necessary.
parrot
Old 2nd June 2008, 07:16 AM   #56
Mooly's Avatar
Make sure you use solder braid to remove the old I/C's and this maybe sounds obvious but we have all done it , when you try and remove I/C/s from sockets prise a bit at a time each end. Try and do it in one go or using fingers and it will flirt out, pins at 90 degrees, probably embedded in your finger. We have all done it
Edit, I will add, when you remove a part clean the pcb (solder) with a cotton bud and iso or meths to get any old flux off. Any mods you do should be indestinguisable from a factory fitted part.
Old 2nd June 2008, 10:14 PM   #57
Hmm, yes ... not particularly looking forward to removing the opamps but I've used braid before so I'm not quite starting from scratch.
Thanks again for the tips ... I'll be reporting back on the results.
parrot
Old 3rd June 2008, 07:10 AM   #58
Mooly's Avatar
Braid is easy, the secret is a hot iron with a large bit well tinned-pleanty of fresh solder on it.
Sounds mad but don't be afraid to add a little fresh solder to the braid as you actually apply it, the flux will help it all get sucked up instantly. Should take about 1.5 to2 secs total per pin on the IC, do each pin one at a time, bend the braid over the tip in a U shape and pull tight as you apply to the pin to unsolder.
Old 3rd June 2008, 01:47 PM   #59
glennb is offline glennb  Australia
I find using a solder-sucker much easier than braid. Its a simple suction device with a manual plunger and trigger. Does one pin at a time.
Glenn.
FS: Opamps Charlez Swap Meet 2 17th August 2008 10:45 AM
FS/WTT: Opamps seiko_citizen Swap Meet 0 20th October 2006 09:23 AM
OPamps xaudiox Swap Meet 2 31st August 2006 02:40 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Nad 5420 display problem harry303 Parts 3 3rd April 2005 06:10 PM
Page generated in 0.09952 seconds (81.27% PHP - 18.73% MySQL) with 11 queries
