My First chip amp.
My First chip amp.
Old 1st June 2008, 02:40 PM   #11
cpemma is offline cpemma  United Kingdom
Default Re: My First chip amp.
Originally posted by mikje
Do any of you DIY-ers have any suggestions for tweaks? Better caps, maybe???
A simple tweak for the preamp board would be better dual op-amps; as they're socketed it's easy to experiment. Apparently they come with TL072, it's not expensive to buy a few more up-market ones to try without going OTT. NE5532 and OPA2134 spring to mind but others may suggest better.
Both these boards use a simple onboard rectifier/smoothing section so on one hand changes to the electrolytics is pretty easy, on the other bypassing this section on the preamp with a regulated (7812 & 7912) supply may give more benefit.
Full preamp details.
K4003 Amp details.
Old 1st June 2008, 04:17 PM   #12
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
My First chip amp.
cpemma,
Thanks for the tips. I found the op amps and regulators at mcmelectronics. Can you explain for this newbie how I would wire the regulator. Also, if I replaced the electrolytics, what would you recommend I use to replace them. What effect on the sound will better, larger electroytics have?
Thanks again for your tips.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 4th June 2008, 09:04 AM   #13
Bluto is offline Bluto  United States
Mikje -
Apologies for going off topic but I'm curious about you 3CR TB's.
Have you tested them with anything yet? Impressions?
Bluto
Old 4th June 2008, 01:02 PM   #14
My First chip amp.
Bluto,
I have been running the 3CRs. I like them a lot. They are light in the base, so I run them with a sub-woofer. I ran them off my Velleman amp; 12-15 WPC. They sounded great. Definitely worth the time and money. They take a little time to break in, so that needs to be kept in mind.
Thanks for asking.
Mike
Old 16th June 2008, 12:46 AM   #15
My First chip amp.
I think I'm being close to finished with this amp. I still have a very slight hum, so I still need to work on some grounding. Otherwise, I think it's finished!
http://www.audiocircle.com/gallery/t...php?album=2191
Old 19th June 2008, 03:57 PM   #16
ambience exists is offline ambience exists  United States
ambience exists's Avatar
I considered getting one of these kits, as the Chipamp.com kits can get pricey...
((AE))
((AE))
Old 20th June 2008, 01:09 AM   #17
Edits is offline Edits  Indonesia
Mikje, that is nice unique amp you have!
Already solve the hum problem? And how do you prevent temp buildup inside the case?
My First chip amp.Hide this!Advertise here!
Which Chip AMP you like most? dynabok Chip Amps 154 12th December 2012 02:23 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 05:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 02:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 12:43 PM
Hot chip! batkey Chip Amps 1 14th October 2004 12:54 PM
