StarGround: where connect the ground pin of the Volume Pot
Old 19th May 2008, 11:26 AM   #1
ygg-it is offline ygg-it  Italy
ygg-it's Avatar
Default StarGround: where connect the ground pin of the Volume Pot
Do you suggest to connect to a star-point GND the ground pin of the volume potentiometer or to connect it to the local ground, close to the opamp?
I think that connecting it to the star-point you may introduce some output signal into the pot....
But, if you connect it to the local ground you can get hum/Rf noise...
NB: the pot is located between two opamp; it is not directly connected to the input socket...
Old 19th May 2008, 12:55 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
The pot should be connected to whatever point is the ground reference for the driving and receiving opamps. You don't want it connected to any point that might have a small contaminating signal on it, or should it modulate whatever point it's connected to (ulikely if a high value) IOW, the star point is the likely candidate.
I may be barking up the wrong tree, but at least I'm barking!
StarGround: where connect the ground pin of the Volume PotHide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
Ground field on pcb - how to connect ? GrzMiL Parts 2 31st December 2008 06:01 PM
connect to circuit with different ground level jegandren Power Supplies 3 23rd April 2008 02:42 AM
Chassis, ground, earth: connect? starbase218 Solid State 3 14th November 2007 08:56 AM
How to connect ground plane to via using Eagle? Ipanema Everything Else 5 23rd October 2006 08:16 AM
Copyright ©1999-2017 diyAudio
