Beginner's Gainclone, HiFi LM1875, The Amplifier Board
Old 15th November 2017, 10:33 AM   #771
R.I.P.
Originally Posted by vj_audio View Post
Mr. Daniel
There are three pinouts on a 200R trimmer. How do I attach it to the schematic? Eagle has 3 pins for all trimmers.
1 Pin = Input
2 Pin = Ground
3 Pin = Output
Am I right?
Thank you
Vijay
For the multi-turn type you have shown there are two pin outs:
the inline version and the offset version.
The offset version has the wiper (pin2) offset to one side from the two outer pins. This prevents the VR being inserted the wrong way round.
The inline version can be inserted either way around.
Pin1 is connected to one end of the resistive track.
Pin3 is connected to the other end of the track.
Pin2 is connected to the wiper.
There is no "ground" inherent to any of these pins
regards Andrew T.
Old 24th November 2017, 04:50 PM   #772
Jishu is offline Jishu
Would the Rod Elliott design work? It has no 1M ohm resistor in the input stage before the 2.2uF bipolar electrolytic capacitor. Could someone explain to me the importance of the 1M ohm resistor.
Thank you.
This project exactly:
Single Chip 25W Amplifier (Project 72)
Last edited by Jishu; 24th November 2017 at 04:52 PM. Reason: forgot to input link
Old 24th November 2017, 05:34 PM   #773
cspirou is offline cspirou  United States
Thank you.
Main reason is to discharge the capacitor while powered off. The value is high enough where it shouldn't effect the circuit, but still provides a path to ground.
Not an issue if a potentiometer is part of your circuit.
Old 24th November 2017, 07:12 PM   #774
R.I.P.
Charge can build up on an open input.
If one were to hot plug, the sudden discharge is multiplied by the amplifier gain and comes out as an almost explosive pulse into the speaker/s
regards Andrew T.
Old 27th November 2017, 09:40 AM   #775
Clueless but avid is offline Clueless but avid  Germany
Hey people,
I'm the new guy. My name is Jochen, I'm 48 years old an located in Germany. I got plenty of diy experience in building & repairing PC's, but I'm totally new to the audio thing.
I've built my first chipamps a few days ago and I love it. As I have no audio equipment at all besides my headphones and a few soundcards, the plan is to build 2.1 active speakers with the option to 5.1 surround for movies.
I'm always pretty broken and I love to repair or build technical stuff, so I deceided to create my own speakers and not to buy a kit. Dumb as I was, I thought just putting the TSP and some dimensions in a PC program would be enough to have my own speakers calculated and ready to build. Ok, its not as easy as I thought, but its fun, an even without the second, not yet complete, satellite and with just a 6db hi-pass capacitor as crossover, to me it sounds great .
Until now I've got two LM1875 for the satellites and one TDA7293 for the subwoofer. As source and active subwoofer- crossover I'm using a Asus Xonar D2X soundcard wich works really fine.
Right now painting is on the schedule, and this really sucks. Not much room, crappy tools, cheap paint ... but I've got time and its getting better. When the painting is done, I'm gonna build the crossovers.
The installation on the pics is just provisionally, but I really like how it sounds. More to come when everything is done.
Click the image to open in full size. Click the image to open in full size.
Old 27th November 2017, 09:53 AM   #776
R.I.P.
Clue,
please attach your pictures.
How to attach images to your posts.
the 1200x900 is probably OK when attached.
The 1726x3065 is going to be too big for most of our screens/monitors.
Crop and compress/resize before you attach.
regards Andrew T.
Old 3rd December 2017, 05:52 AM   #777
dannyjmf is offline dannyjmf  Saudi Arabia
dannyjmf's Avatar
Can I use it for small subwoofer?
Depends on the subwoofer driver wattage rating ... but it is not recommended as if the LM1875 was overdriven into clipping it sounds nasty ... based on my past experience
Mohamad Danny Al Saleh
Old 8th December 2017, 07:01 PM   #778
kurtvisti is offline kurtvisti  Denmark
Hi Daniel
I’m in the process of building the amp according to your fine instructions.
As I understand there are 2 choices of schematics. The “original” one shown in post #1 and the Turbo II. Is that correct?
What are the differencies in sound between the 2 layouts?
In short: Which one should I build if best sound quality is wanted?
Regards Kurt
Old 16th December 2017, 06:07 PM   #779
Hi folks
1. What is the purpose of the 1R 3w resistors in the power supply from post #1?
2. Which components "need" to be of good quality and which doesn't in order to make the amp sound its best?
3. What specs do you recommend for these better quality components (resistors, capacitors)?
Kurt
Old 16th December 2017, 06:50 PM   #780
Mooly's Avatar
As no one has spoken I'll give my thoughts:
The 1 ohm resistors increase the impedance of the supply as seen by the transformer and so help reduce the overall 100/120Hz ripple more effectively than if they were not present.
The downside is that they reduce the 'stiffness' of the supply meaning that the regulation becomes poorer i.e. the rails will sag more under sustained load. Its the designers choice to do it this way.
All parts should be of good commercial quality and (imo) exotic or boutique parts are not required.
The electrolytic caps should be a reputable brand and of 105C temperature rating. Resistors (unless specified otherwise) should be metal film types of 0.5 or 0.6 watt and 2% or 1% tolerance. The 1 ohms you asked about would typically be a small wirewound vitreous enamel type.
The 2.2uF input cap should be a film type.
Beginner's Gainclone, HiFi LM1875, The Amplifier BoardHide this!Advertise here!
Beginner's Gainclone, Safety and, The Power Supply Board (please contribute) danielwritesbac Chip Amps 118 18th June 2008 06:12 PM
Beginner's Gainclone, LM3875, The Amplifier Board danielwritesbac Chip Amps 37 22nd May 2008 06:43 PM
