Beginner's Gainclone, HiFi LM1875, The Amplifier Board
Old 5th July 2016, 08:52 AM   #681
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Nag View Post
Dear Andrew,
I am completely newbie on amp/audio circuits. Some times even I don't understand technical words like feedback/zobel network/star earth ground bla bla. So as per your reply PSU is ok except c5 and c6. Can I through that amp and start build own amp form National semiconductor or form this DAN reference circuit. Which one is good ?. Speakers have efficiency 85.5dB 8ohm.
Thanks,
Nag.
To that, I would have to ask, what power voltage have you planned to use?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 5th July 2016, 09:26 AM   #682
Nag is online now Nag  India
Dear Daniel,
Input 230 AC,
OUT PUT 15V-0-15V 5AMP 150VA as per Andrew suggestion.
Thanks,
Nag.
Old 11th July 2016, 03:51 PM   #683
Originally Posted by AndrewT View Post
remove S1 & S2 Fuses here need to be so big to survive start up that they offer no safety advanatge when something goes wrong. A close rated mains fuse is far better at giving the required safety.
remove C5 & C6. They are more likely to increase ringing on the supply lines.
They cannot offer lower impedance seen from the amplifier because they are too far away. Local Supply Rail Decoupling has to be LOCAL to where the currents change.This sch is completely ****** up. Is that an interpretation of what Daniel is giving you?
Go back to the datasheet from National and start with that.
Then add in filters at the input and Thiele Network at the output and proper Local Supply Rail Decoupling.
Dear Andrew and members,
Now I am going to build with official schematic, Please let me know what changes need to done like capacitors/resistors. and any modifications or valuable suggestions.
Click the image to open in full size.Click the image to open in full size.
Last edited by Nag; 11th July 2016 at 04:01 PM. Reason: images not loaded properly
Old 13th July 2016, 10:28 PM   #684
R.I.P.
add an RF filter to the input.
Change C2 to 100uF
Make sure that R1, R2 and C2 connect to input signal return.
Why is 2200uF fitted to output? It has no C number ! Did you add it to the sch?
regards Andrew T.
Old 14th July 2016, 04:31 AM   #685
Change C2 to 100uF
I added 2200uF as per previous suggestions as protection to speaker.
I didn't get you exactly "add an RF filter to the input"
I didn't get you exactly "Make sure that R1, R2 and C2 connect to input signal return". I have 3 wires as input "left channel wire , right channel wire, ground wire"
Old 14th July 2016, 04:39 AM   #686
keith_correa is offline keith_correa  India
Who suggested this and where was this suggested?
Old 14th July 2016, 06:08 AM   #687
I red in diyaudio forums as decouplig capacitor will improve bass and it protects speaker.
If it is not required I will remove no issues.
Old 14th July 2016, 12:50 PM   #688
R.I.P.
A decoupling capacitor is completely different.
You have fitted a DC blocking capacitor. This blocks an output stage failure generated DC damaging you speaker.
Instead of a DC blocking capacitor you can fit some form of speaker protection.
I do recommend some form of speaker protection !
regards Andrew T.
Old 14th July 2016, 12:58 PM   #689
R.I.P.
I always recommend that the input to our equipment be fitted with band limiting passive filters.
These come in two forms and both are required.
A low pass passive filter attenuates very high frequencies.
A high pass passive filter attenuates very low frequencies.
The High Pass filter needs two components A capacitor in series with the input signal Hot line and then a signal grounding resistor from Signal Hot to Signal Return. You have both these components (C1 & R2) shown in the sch.
The Low Pass filter needs two components A resistor in series with the input signal Hot line and then a signal grounding capacitor from Signal Hot to Signal Return. You have neither of these components shown in the sch.
Typical values are 200r to 3k for the series resistor and 220pF to 2n2F for the grounding capacitor.
Both filters need some fine tuning to get their roll-off frequecy to meet your needs. You expect ALL the audio signalto pass and expect ALL the interfering signal to be blocked. You cannot meet this idealised performance requirement. You adjust till the compromise is acceptable. Allowing an F-3dB for each filter about a decade outside the required audio bandwidth satifies most Builders/Listeners.
regards Andrew T.
Old 20th July 2016, 09:17 AM   #690
I added [series] 2200uF as per previous suggestions as protection to speaker.
If the speaker is bigger than 4 inches, double that capacitance. Match it to your speaker's needs.
Also, if you have a split-rail powered amp, it would be nice to put the series capacitive speaker filter close to (nearby) the speaker, not close to the amp; and, in the case of a split-rail powered amp, put your series capacitve speaker filters at groundside (speaker negative).
The Low Pass filter needs two components A resistor in series with the input signal Hot line and then a signal grounding capacitor from Signal Hot to Signal Return. You have neither of these components shown in the sch. Typical values are 200r to 3k for the series resistor and 220pF to 2n2F for the grounding capacitor.
When the source is a modern computerized sort, I'd add 470p~560p parallel to the ~22k input load resistor. Round about that much loading does seem to clean off what I didn't want to hear, without reducing what I wanted to hear.
I can't tell you very much about it, except that I'm sure it is worthwhile to add the parts for it. Thanks for suggesting it.
Beginner's Gainclone, HiFi LM1875, The Amplifier BoardHide this!Advertise here!
Beginner's Gainclone, Safety and, The Power Supply Board (please contribute) danielwritesbac Chip Amps 118 18th June 2008 06:12 PM
Beginner's Gainclone, LM3875, The Amplifier Board danielwritesbac Chip Amps 37 22nd May 2008 06:43 PM
