| Chip Amps Amplifiers based on integrated circuits |
#151 |
For the original at post 1, circa May 2008, here is a slightly revised schematic, with the updates, protection, and quality control patches added. I've also modified the speaker zobel to use 1/4 watt resistors for lower cost.
If it is your intention to crack the plaster rockin the house with an LM1875 chip, I would suggest to Avoid this mixed coupled design. Mixed/direct coupled designs provide a flatter response by omitting an important signal capacitor and that omission causes decreased dynamics and decreased durability. The design posted below is for near-field, mixer-desk, a point of reference, and for relaxing with a non-shout amp that has good resolution and a flat response. It is very helpful for near-field/mixing so that you don't accidentally overdo the audio compression on tracks. The intended source is a computer sound card. The gain is rather high on this amplifier so that you don't have to turn the computer up high enough to strain/clip itself. This was thoroughly checked out with RMAA software and a very wide variety of computer chips and sound cards. It does also need mains fuse and speaker jack fuse. Monobloc/dualmono is suggested so that you can somewhat control current via transformer selection and so that you can enjoy wider imaging.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#152 | |
Thanks again. This will be in my office system using Panadora for tunes thru our iPod. Found some 50k pots here...so just add it before the 1st resistor? Can I or should I eliminate any resistors? I want something down and dirty...build once and forget about it...let her play. |
#153 |
Hello !
About schematic above , post #151, on outpout there are 6600µf non-polar capacitors... What is your explanation about ? Not easy to source (or electrolytics polar 12000µf series connection ?) Thanks |
#154 |
I don't find much logic either in avoiding a cap in the feedback loop (so it amplifies DC) and then adding huge (unneeded) caps in the output. ¿¿??
#155 |
![]() I know it's an old post, but am I the only one who turns "pentawatt" type chips forty five degrees, so they fit nicely in the 2.54mm 1/10" matrix and you don't have to stretch them as shown above? Also, I had good results with lm1875 into (nominally) 4 ohms 88dB speakers, though not with this threads schematic or voltage. |
#156 |
Well, spreading their legs open doesn't hurt anyway.
Doesn't turn them 45º complicate mounting? And yes, power is more than enough for home listening with typical "HiFi" speakers ![]() I'm using a couple TDA2050 (which is about the same) as PC monitors. Sure beats the "200W PMPO" 2" plastic speakers powered from the 5V USB connector
#157 |
Yeah, i;m probably a little OCD about finding that perfect fit. Doesn't really complicate mounting. I just cut the board diagonally if the sink is too big to sit on/above the board.
#158 |
Were my questions above to dumb to warrant a response from anyone
#159 | |
I answered YOU in post #149 As of BOM, choose one schematic of the various posted and write a parts list down. Less than 10 items anyway. |
#160 |
Sorry Fahey- I don't understand- post #149 is about heat syncs
| Beginner's Gainclone, Safety and, The Power Supply Board (please contribute) | danielwritesbac | Chip Amps | 118 | 18th June 2008 06:12 PM |
| Beginner's Gainclone, LM3875, The Amplifier Board | danielwritesbac | Chip Amps | 37 | 22nd May 2008 06:43 PM |
