What are you guys using for speakers with your amps?
Old 20th May 2008, 07:32 AM   #11
ianpengelly is offline ianpengelly  United Kingdom
ianpengelly's Avatar
Monitor Audio Silver 9i
Though these will eventually be replaced with a pair of the Amish 45/97, which is a Troels Gravesen design from:
http://www.troelsgravesen.dk/Amish_8545_9500.htm
I have all the components, but need to build the cabinets, unfortunately I have been distracted by my OPA627 buffer for my preamp and the fish tank lid I had to build to keep the girlfriend happy!
Old 20th May 2008, 02:41 PM   #12
wboyd is offline wboyd  United States
My current lineup includes:
Magnepan SMG a/b running at a 4 ohm load - easily drives my 3886 to clipping at louder volume! Still sounds great. I love the sound of these ribbons.
Parts Express BR-1 with modded crossover...good stereo imaging (depending on placement)
An old pair of DCM CX-07 from the early 90's. Still sound quite good....but could use a new woofer - anybody got recommend a suitable replacement?
And last but not least a pair of Fostex FE103 back loaded horn design....Fostex recommended enclosure.
Wayne
"I am always doing that which I cannot do, in order that I may learn how to do it"
Old 21st May 2008, 04:56 PM   #13
valleyman is offline valleyman  United Kingdom
Zaph ZD5s. They're very inefficient at only 83dB/W/m but this doesn't seem to be much of a problem. I don't listen at high volumes much and 50W is plenty
Old 22nd May 2008, 07:55 AM   #14
Bgt is offline Bgt  Netherlands
see sig.
Kind regards,
Bert
Old 22nd May 2008, 01:56 PM   #15
ionomolo is offline ionomolo  United States
ionomolo's Avatar
Send a message via MSN to ionomolo
Hey, i have to buy some new nice-sounding speakers for my chipamps (100W Bridged, 100W LME49810, no 10W or less and high sensitivity requires hand-macthing of neighbours). My ideas where the arround $1K tannoy (between DC2 and DC6) Monitor audio, B&W bookshelf and Kef iQ. Any advise?
Old 22nd May 2008, 04:47 PM   #16
DIY! If you have $1000 to spend I cannot recommend Zaph's ZD5s enough, though I will admit for a lot less money you can come very close in terms of performance...
There are many excellent designs out there to fit everyones needs, I'd recommend asking over in the Loudspeaker forum.
Many people also really enjoy fullrangers with chipamps
If DIY isn't an option, I have used my GC with a pair of MA GR10s and it sounds lovely
Old 22nd May 2008, 05:29 PM   #17
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Talking of Monitor Audio, I heard a pair of GR60's bi-amped by (4) 'basic' GC's and they sounded fabulous!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 22nd May 2008, 07:52 PM   #18
ionomolo's Avatar
There is one thing that deters me from buying monitor audio loudspeakers, and the thing is that i've read about both people who loved them and people who hated them. This does not happen with tannoys or kef's. Stereophile has a good review of one of the iQ's, despite alien's perception of sound is ok i would also like to hear something from humans. What about JBL's?
Old 22nd May 2008, 08:54 PM   #19
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
I have some 7" and 8" wideband (almost full range) drivers. They're 4 ohms, done 1st order so they're more like 5 ohms (cheap inductor). They have a cap so small that its not even in the audio band, and that's directly across the terminals. Its for speed, via inductance compensation.
I also have some rather speedy 12" at 4 ohm woofers, also with the cheap inductor, so they're more like 5 ohms. They're done standard 2nd order, with the resulting cap boost filling a hole in their response quite nicely. Just one of them is about 98db on the first watt.
I tend to choose tweeters that are "the higher the louder" format, just because, if the FR chart goes like a slippery slide, hey!, at least there's no crazy peaks. Of course, this makes my wideband drivers have to play clear up to 4k. Its done via driver selection.
Generally, there's more than two loudspeakers in use; however, the main two channels play on classic hifi, except. . .
There's the most haywired preamplifier ever--a quad parallel arrangement with a baxandall. It can be switched on or off, depending on the type of music played.
The chipamps? Either LM1875's or TDA7294's, and sometimes both.
Well, that's my computer speakers and amps. There's something a bit larger in the workshop.
Old 23rd May 2008, 12:03 AM   #20
casiomax is offline casiomax  Indonesia
I have a TDA2050 mono amp for my guitar, I am using celestion vintage-30 G12... sounds great!
What are you guys using for speakers with your amps?Hide this!Advertise here!
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Active crossover guys.....what amps do you use? demon2091tb Multi-Way 58 28th November 2006 06:22 PM
Here is a great tip for you guys building aluminum chassis for your amps russbryant Pass Labs 39 28th November 2004 01:19 AM
[pics] What do you guys think of my new speakers? PooJou Multi-Way 19 30th June 2004 04:09 PM
Hi Guys! I'm one of the Portuguese Guys who love diy sapito Introductions 3 2nd September 2002 02:19 PM
