| Chip Amps Amplifiers based on integrated circuits |
I was trawling through some op-amp pdfs and saw a diagram for a dual 9v battery supply where the ground came from a resistor divider, as is in "split" supplies for single battery setups.
wouldn't it be better, though, just to ditch the divider, and use the center tap between the batteries as ground? I thought this would allow more current to be drawn and increase headroom, but maybe there is some drawback that I'm not aware of? any pros/cons to either config? |
#2 |
The solution you suggest is certainly easier to build. The current to be drawn remains the same, so don't expect more headroom. If you want more current, you need to connect batteries in parallel. But don't, because they are never charged at the same level and discharge each other trying to find an equilibrium.
The drawback of your idea might be that you don't have a symmetric power supply, when the batteries are not equally charged, e. g. if one of the batteries is empty and the other is full. The divider with two batteries in series would maintain the symmetry even in that situation. |
#3 |
Yes I use the second method for my BB op amp head amp, just using 2 9v batteries with centre tap. when the sound starts degrading I change both batteries, but I've had the thing for 2 years now and only have changed the batteries once. (use an 18v wall wart mostly).
#4 |
I thought I noticed an improvement in sound quality, though, without the divider. I guess it isn't current draw, but could anything else about this setup be benefiting the sound?
#5 |
The divider is drawing current. That loads up the PSU (batteries).
Reducing the current draw gives the PSU an easier job and rewards you with improved sound.
regards Andrew T. |
#6 |
so the opamp actually, gets less current with the divider?
#7 |
no
regards Andrew T. |
#8 |
The 9V cells in series works great, use the CT (ground connection) of the batteries as circuit ground..
If this was a speaker amp, you get better bass by using the real ground instead of a resistor divider. However, OpAmps don't make much difference with bass because of the lower currents, but using split supplies IMO gives cleaner sound, because the input of the amp goes directly to 0V point, instead of resistors which could pick up noise easier, which is why they usually filter a resistor divider with a capacitor. Also, it uses less parts and IMO is easier to build as well to just use the batteries instead of the divider. IMO the biggest reason to avoid a divider is that it adds extra drain to the batteries to shorten their usage. |
#9 |
yup, it wasn't the divider that was affecting the sound, after all
| Symmetric supply or dual supply? | JWFokker | Parts | 32 | 11th August 2011 08:29 PM |
| Dual supply for LM1875 split supply | dovganj | Power Supplies | 30 | 6th November 2009 03:19 AM |
| confusion in the resistor/capacitor values and B+ supply for the aikido | jarthel | Tubes / Valves | 1 | 23rd May 2006 12:58 PM |
| Power Supply Ground Confusion | Dwiel | Everything Else | 11 | 24th June 2005 07:46 PM |
| Power supply confusion | ShieldJaguar | Chip Amps | 4 | 25th June 2004 09:39 PM |
| Page generated in 0.09005 seconds (77.47% PHP - 22.53% MySQL) with 10 queries |
