Old 16th May 2008, 03:32 AM   #1
evo9 is offline evo9  United States
Default Opamp?? FET vs Bipolar
Hey guy's please shine some light on this for me. I have red somewhere that you should not swap out FET opamps with bipolar's. But I have never been able to find, or read the reasons why this is not a good practice. I have seen on other forums, where someone modded a sound card going form FET to bipolar. They said the modd has improved the sound card.
Old 16th May 2008, 11:21 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Opamp?? FET vs Bipolar
There is at least one technical reason: most bipolar opamps have orders of magnitude more input bias current than FET input opamps. Depending on the circuit details, the increased bias current can cause appreciable DC offset at the output. Again, depending on the circuit, this may or may not upset or even damage your system.
It should be clear that indiscrimiate changing of device types without having a good look to the consequences is a bit like playing Russian Roulette.
Jan Didden
Old 16th May 2008, 11:26 AM   #3
Default Re: Re: Opamp?? FET vs Bipolar
agreed, informed decisions are usually better than guesswork.
eg. filters generally assume zero source impedance and infinite load impedance.
FET input stage gets closer to this than BJT for the load.
BJT output stage might be better than FET output stage for the source side. But are any opamps built with FET output stage?
regards Andrew T.
Old 16th May 2008, 11:40 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
Andrew, no to your last question if you'll exclude CMOS opamps.
/Per-Anders (my first name) or P-A as my friends call me
Old 16th May 2008, 11:42 AM   #5
peranders's Avatar
You have a drawback with JFET's, higher distortion under certain conditions.
Walt Jung has written some about it.
http://www.analog.com/library/analog...inal_PtB_F.pdf
Page 5.108
What Walt Jung writes here is unknown to most people I should think. I hadn't heard it before I read it in Walts book.
Compare this when folks are tweaking and it got soooo much better. Sometimes maybe the distortion higher with a better opamp?
Old 16th May 2008, 10:17 PM   #6
Thanks for answering guy's! I was about to swap out some opa2134ua with ad8599arz. Then I remember they were FET & Bipolar. I got some ad8066arz, I will use instead. I am trying to improve the sound of my pioneer car stereo.
Old 17th May 2008, 11:05 AM   #7
if you equate zero distortion with sounding better than some distortion/colouration then putting the Pioneer in the bin is the best improvement you can use.
regards Andrew T.
Old 17th May 2008, 10:07 PM   #8
nelsonvandal's Avatar
AD8599 is a very good opamp. Much better than OPA2134 to my ears. I don't think you're getting in to any trouble just swapping them.
Old 18th May 2008, 07:47 AM   #9
You may have a point there! But its already paid for, may as well do what I can with it. There is always the Alpine F1 if I want to.
Bipolar PS plus AC coupled output from opamp? leadbelly Solid State 6 28th July 2009 12:12 PM
Cancelling DC Offset in a bipolar Opamp ygg-it Chip Amps 16 5th May 2008 05:47 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
What preamp should i build for my 3886 GC??Tube?MOSFET?OPAMP?Bipolar?? thomgun_lc Chip Amps 45 14th August 2005 05:27 PM
Page generated in 0.12762 seconds (77.86% PHP - 22.14% MySQL) with 11 queries
