My STK4050 amp.
My STK4050 amp.
Old 11th May 2008, 05:44 PM   #1
CECCO is offline CECCO  Italy
CECCO's Avatar
Default My STK4050 amp.
This is a 200Wrms into 8Ω load.
In addiction to the original circuitry, there are DC protection ,Power on delay and power off cutoff.
The sound "sounds" very good to me.
I was concerned about the thermal behaviour.
Just after half an hour of normal use, the heatsink was very hot (untouchable with bare hands).
I've build also an inproved version with larger caps and better snubber.
When testing it at full power with a dummy load, I switched the function generator in the 100KHz range blowing the chip. The result can be seen.
ciao.
Old 12th May 2008, 02:49 PM   #2
CECCO's Avatar
I attacched an image but I don't understand why it's not there.
The size was around 1.5M
Old 12th May 2008, 02:49 PM   #3
CECCO's Avatar
Sorry but since I can't edit posts I have to add one.
Witch is the procedure to show pictures in a thread?
thanks.
Old 13th May 2008, 07:41 AM   #4
CECCO's Avatar
pic1
Old 13th May 2008, 07:41 AM   #5
CECCO's Avatar
pic1
Old 13th May 2008, 07:41 AM   #6
CECCO's Avatar
pic2
Old 13th May 2008, 07:41 AM   #7
CECCO's Avatar
pic3
Old 13th May 2008, 07:41 AM   #8
CECCO's Avatar
pic4
Old 13th May 2008, 07:41 AM   #9
CECCO's Avatar
pic5
Old 13th May 2008, 07:41 AM   #10
CECCO's Avatar
pic6
My STK4050 amp.Hide this!Advertise here!
STK4050&4044 pcb+schema test ok gev Chip Amps 22 21st March 2011 02:58 PM
stk4050 parallel Hannes.Soobik Solid State 5 25th November 2008 07:07 PM
help with STK4050 skobo Chip Amps 4 14th June 2005 03:34 AM
Copyright ©1999-2017 diyAudio
