| Chip Amps Amplifiers based on integrated circuits |
#81 |
Going from stereo intégrated amp to monoblocks is a first step ; second step is biamping and the third one is active crossover...
#82 |
Any word on pot values yet?
I just read thru and didn't find anything. Thanks |
#83 |
i purchased this kit last year and unfortunately did not received the shematic as it have to be happen. Could you please send me the shematic of the pcbs for further reference. Many thanks br Attila |
#84 |
#85 |
#86 |
The TA-package has a non-isolated (metal) heatsink tab that is connected to the negative power pin.
The TF-package has an isolated (plastic) heatsink tab. Improved electrical isolation with the drawback of higher thermal resistance.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#87 |
what psu capacitors are used?
I need part numbers please. |
#88 |
diyAudio Moderator Emeritus
1500uF Panasonic FC
Digikey Part Number: P10334-ND |
#89 |
Hello,
my LM1875 chipamp kit - a stereo integrated am with alps pot and a 160va 2x18v transformer, and the 2x1500µf stock cap on psu board - produce a strong plock when I turn it off ; any input about this trouble ? I solder on the snubber parts, which is not necessary with the 2x1500µf configuration, is this the cause of my problem ? |
#90 |
I don't think the 1875 has a mute function.
You might have to fit a relay switched output to the speaker terminals. This can double up as an delayed switch on to give time for the other parts in the system to reach a quiet state and can also be used as a speaker protection relay in the unlikely event of speaker damaging faults developing.
regards Andrew T. |
| LM1875...how low can you go? | Gcollier | Chip Amps | 7 | 6th May 2010 03:43 AM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 01:29 AM |
| Finally made it in the PassDIY pages! | Blues | Pass Labs | 23 | 28th July 2004 04:05 AM |
| Lm1875 | soundNERD | Chip Amps | 14 | 12th October 2003 02:26 AM |
| Finally made a new webpage! | Duo | Everything Else | 24 | 17th January 2003 12:29 PM |
| Page generated in 0.08656 seconds (78.92% PHP - 21.08% MySQL) with 11 queries |
