| Chip Amps Amplifiers based on integrated circuits |
#142 |
Hello all!
Is there a difference between the feedback in this amplifier made with resistors: [(200k/10k) +1, and [(20k/1k) +1], if there is in what? If measurements can? thank you |
#143 |
The higher values will lead to more Johnson noise. Whether that becomes audible depends on the rest of your system, especially on the sensitivity of your speakers.
You will notice a difference in DC offset. Depending on the parasitic capacitance of the PCB, higher values resistors can lead to different amp behaviour at high frequencies and can make it necessary to use a compensation capacitor, when you wouldn't need one with lower resistor values for the same gain.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#144 |
You wouldn't want the feedback resistor higher than 115k. I doubt if you'd actually want it that high, but 200k is not especially valid nor desirable for LM1875 non-inverting amplifier.
#145 |
High values of NFB resistors allow lower values of DC blocking capacitors.
This can be a very good compromise if you want to adopt AC coupled amplifier with wide audio bandwidth and do not want to use any polarised nor electrolytic capacitors. If the Power amp gain is relatively low then 200k for both Rin and NFB upper leg resistor will not create much additional noise. If you use Cherry's suggested NFB, the Rin resistor can be 3 times the NFB upper leg resistor and still maintain DC balance of LTP currents/voltages.
regards Andrew T. |
#146 |
From BrianGT in 11th post -"Wire one of the GND connections on the PSU board to the chassis ground."
Would any of the 4 holes marked pg+ or pg- be the ones? And share it with a wire that goes to the amp board? There is no chassis yet. Where would the chassis gound be made? |
#147 | |
But the good news is that this 3.9k is within range to use a 100uF cap for NFB cap, and the great news is that it is very easy to find excellent quality 100uF (and smaller) caps. This can be paralleled with a really tiny value polyester dip cap for excellent results since the frequency response will stay level. At this point, NFB cap selection gets extremely easy. Do you mind posting a sketch involving the Rin resistor value relating to your comment about Dr. Cherry's NFB tapping? If I remember correctly, the speaker zobel resistor has to be a 3w or better model so as to avoid accidentally releasing the feedback loop upon resistor failure. Probably a less expensive resistor could be used if speaker zobel cap is 22nF. Its still enough to block some RF, but the smaller value cap removes some risk, and nobody would ever have an excuse to remove the zobel for audio purposes since that is so very far above the audio band.
#148 |
I've sent BrianGT this question via email along with some other kit-related questions, but this should be super-simple to answer here. For the kits purchased from chipamp.com -- are the LM1875T chips meant to be included in the kit, or not? The kit I received included everything but these chips and I was trying to figure out if the omission was intentional or not.
#149 | |
#150 |
Would it be possible to replace the 22k resistors on BrianGT's amp boards with 1/4 watt instead of 1/2 watt. Having a hard time sourcing 1/2 watts that small in Canada. Thanks for your help.. JohnnyP
| LM1875...how low can you go? | Gcollier | Chip Amps | 7 | 6th May 2010 03:43 AM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 01:29 AM |
| Finally made it in the PassDIY pages! | Blues | Pass Labs | 23 | 28th July 2004 04:05 AM |
| Lm1875 | soundNERD | Chip Amps | 14 | 12th October 2003 02:26 AM |
| Finally made a new webpage! | Duo | Everything Else | 24 | 17th January 2003 12:29 PM |
| Page generated in 0.10479 seconds (85.11% PHP - 14.89% MySQL) with 11 queries |
