Old 8th December 2011, 12:14 PM   #131
Originally Posted by danielwritesbac View Post
I can probably listen and guess from there
Guessing is the least efficient method. It is not likely that you guess the right values. Don’t be fooled by people who claim to have found by guessing and listening that certain snubber values in a power supply lead to a better sounding amp. That is only marketing.
whereby average cooler is better stability.
An amplifier can be unconditionally stable, conditionally stable or unstable. There are no intermediate states, like 58 % stable is better than 59 % stable. You want either an unconditionally stable amp or an amp that is conditionally stable as long as it is used appropriately. Increased heat dissipation may indicate oscillation, but the opposite is not a reliable proof of the absence of oscillation.
The project is indefinitely held up over sound field size (low resistor values) versus a favorable tone (high resistor values), because the two necessary features seem to be mutually exclusive when you try to do it with resistor values alone.
The range from about 15 kHz upward is responsible for this impression. Increasing the volume of that frequency range provides more “air” i.e. appears to create a bigger sound-field, while decreasing that range makes the sound more pleasant.
By increasing the gain, you create a lower frequency roll-off, and by that affect exactly the frequency range above 15 kHz. So, yes, they are mutually exclusive and you can only choose the compromise that suits you best. If you plan on making that a group project, you should however consider that those differences may be much smaller than the ones from one speaker to another. You will need to find the right compromise for different speakers, not only for yours.
One odd thing is the DC performance,
What is DC performance?
which is always going to be better with a 10k input load than 100k input load. However, the 10k+feedback shunt+stopper constitutes resistor comp. For example 10k input load, 475R stopper, 1k feedback shunt = 11.47k resistor compensation.
I assume that resistor compensation is supposed to mean that both inputs see the same impedance to ground. From a DC point of view the amp cannot see what you call the feedback shunt resistor, because it is in series with a capacitor which blocks the path for DC. The inverting input sees ground through the feedback resistor + load. The non-inverting input sees ground through the input resistor + stopper resistor. A stopper resistor is not necessary for the LM1875. If you want the same DC impedance, you choose the input resistor and the feedback resistor to be of the same value.
Instead of my gain comp, your cap comp could give a similar performance and probably better performance. Did I guess right?
The cap is primarily there for stability. It can be abused to shape the HF roll-off for a low gain to make it similar to the natural HF roll-off with high gain. Alternatively you could use a corresponding HF filter at the amp input.
I'm not skilled in math, but for me, examples can usually explain the figures. My grip on the topic is still infirm, but am possibility beginning to understand.
Here is a picture.
An amplifier with a phase turn of 135° or more at unity gain is considered unstable. Less than 135° are considered stable. Conditionally stable means that e.g. a high capacitance at the output can increase the phase turn of an amp so that it becomes unstable, although it is stable on the condition that the load is resistive.
The upper graph shows an amp compensated with 22 pF in parallel to the feedback resistor and 220 pF between the input legs. The -3 dB point is around 120 kHz and consequently the amp is 0,1 dB down at 20 kHz. Phase at unity gain (frequency where the gain crosses 0 dB, here about 2,4 MHz) is around -118°. The amplifier is stable and has a margin of 17° to deal with capacitive loads.
The lower graph shows the same amp uncompensated. The -3 dB point is around 400 kHz. The amp is down only 0,01 dB at 20 kHz, but at unity gain (around 7,4 MHz) you see that the phase turn is -141 ° which means this amp is not stable and very likely to oscillate.
So if your amp oscillates those capacitors can cure that at the price of earlier HF roll-off and as usual, the bigger the capacitor, the lower is the roll-off frequency.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 8th December 2011, 02:14 PM   #132
Well explained Pacific.
I followed every word.
There are a couple of minor details, where I don't agree exactly on values but that is verging on opinion rather than the science.
Old 9th December 2011, 09:05 AM   #133
danielwritesbac's Avatar
Thank you again.
I'm aware that snubber values cannot work except for the specific model of transformer, layout and situation for which they are specific.
I have been able to make use of RMAA; however, I do also find that some of its reports are about ten times understated. . . because its either ten times off or else I can hear 0.03db. One of those is true. I do not know which. However, errors detected are always at the same frequency and in the same direction.
A more useful thing to do with the computer, but I don't know if its available, would be to play a square into itself and zero out any variance from perfect, and then next enclose the amplifier into that loop and look at the square wave difference. Is there not yet some incredibly simple way to do this?
Old 9th December 2011, 09:17 AM   #134
HI Pacific @ Post 131.
That is a well written very useful informative post not that im a description expert by any means. Andrew t understands it although he has much much more amplifier design knowlage than me. For me to understand nearly every word Is amazing and you have certainley cleared up an area i was having a few problems with.. THANKYOU.
Regards Ian
Old 9th December 2011, 08:15 PM   #135
Yes, there is. You need a square wave generator and an oscilloscope. For good results you will need solutions with additional hardware. The sound card's upper frequency limit is usually OK to use purely software-based (even freeware) signal generators and oscilloscopes for speaker design, yet too restricted for thorough amplifier diagnostics.
Old 16th December 2011, 01:48 PM   #136
audiosteve's Avatar
I have been through this entire thread and also have written BrianGT four times and gotten no response. No links to any docs seem to work. I have the Chipamp 1875 kit. But I would like to get a schematic, parts list and possibly some instructions before assembling it. Does anyone know where I can find these? I find it unbelievable that Brian would sell these kits without these and furthermore would completely ignore all communications regardng the kits he sells. This is not cool at all. I'd appreciate getting help from anyone at all at this point. Thanks much.
Nihilism is best done by professionals.
Old 16th December 2011, 02:43 PM   #137
jemraid is offline jemraid  United Kingdom
Hello Steve,
The parts list is here: LM1875 Amplifier Kit | Chipamp.com
The LM1875 datasheet will give you the diagram
My personal opinion is that point to point wiring is much easier.
Jim
Old 16th December 2011, 02:50 PM   #138
audiosteve's Avatar
Thank you Jim,
The parts list link is helpful. I should have seen that myself. Didn't scroll down far enough to see the PCB part number designations. So the schematic in the national data sheet is exactly the same then? If so that helps quite a bit. That should do it.
Thanks much,
Steve
Old 16th December 2011, 05:01 PM   #139
Hello Steve,
Well it can't be far off the datasheet they never are :-)
Here's a pic of my latest effort p2p around the chip as I said above;
Jim
Old 16th December 2011, 05:34 PM   #140
audiosteve's Avatar
Thanks again Jim. I see point to point is certainly doable. But I'll use the boards this time. I suppose the boards are simple enough that I can trace the lines and accurately reconstruct the schematic to be sure it follows the NatSemi data sheet. But I was hoping to avoid that. Either way I think I have enough data at this point to have a go at building the amp.
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 03:43 AM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
Finally made it in the PassDIY pages! Blues Pass Labs 23 28th July 2004 04:05 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
Finally made a new webpage! Duo Everything Else 24 17th January 2003 12:29 PM
Copyright ©1999-2013 diyAudio
