| Chip Amps Amplifiers based on integrated circuits |
#181 |
@Stream
You got PM
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#182 |
Pacificblue,
PM? Havn't any new PM... |
#183 | |
exactly but start with the regular one first such as the wima then gradually to more expensive and so called audiophile cap to hear improvement..... good replacement for the opamp is just go for discrete type... finish mine but put on halt for a while..... ![]()
#184 | |
#185 | |
P.s. I recieved one strange mail from "mountain@..." recently, but I think it's not You, right? Plz try manualy to mxs.stream @ gmail.com |
#186 |
I,m putting the final touch on a "new" version of the SOAP and i am going to order a few boards.
I,ll post some more info when time is...... Changes are small and will mostly be to match parts to a specific partnumber on Farnell or mouser or something.. Also transformer onboard is considered... (not decided on this yet though) The regulators will be standard 7815/7915 to even more reduce cost and number of parts. (No change in sound) Input cap is on the loose.. (No final desicion on this either yet) Suggestions are of course welcome.. Later /JZ
Tala är tiga, silver är guld |
#187 |
#188 |
If you are going to have them professionally made go double sided!..
Cost is usually the same but much better layouts possible and can be compacted. Will you offer any PCB's for sale when completed?
Troy Thinking positive doesn't make things better, it makes you a better person. |
#189 |
Hey Stream, They looks really good man. Ive wanted a PCB for the SOAP for a while, any chance you can make me one?
www.drugfreeworld.org |
#190 |
Hi.
Mike, yes, it's possible, I just need to buy more pcb... Here is my SOAP, its almost done.. Just need to add pots and adjust voltages. Btw, I changed three values (according to parts, which was in by box...) 1. LM317 - resistor from 120 to 160R. 2. Input RC - resistor from 15k to 20k. 3. small capacitors - from 100nf to 68nF. As I understand these replacement are safe, right? ![]()
| A Simple opamp question? | Dxvideo | Chip Amps | 29 | 3rd April 2009 01:42 PM |
| SOAP - Simple OpAmp Pre | zei | Chip Amps | 14 | 12th December 2007 02:15 AM |
| Looking for Simple 12V supply dual opamp for kid's project | chipco3434 | Chip Amps | 26 | 16th March 2006 07:13 PM |
| Designing a simple tube opamp? | bradd | Tubes / Valves | 1 | 26th October 2005 06:24 AM |
