SOAP MKIII (Simple OpAmp Pre) With onboard PSU - Page 13 - diyAudio
Old 17th January 2009, 07:20 AM   #121
zei is offline zei  Sweden
All boards are gone no new ones are planned within a near future..
The tripots can of course be subsituted with a resistor.
Howeverthe reason for the trimpot is to easy trim the voltage coming from the PSU part.
Thanx
/JZ
Tala är tiga, silver är guld
Old 17th January 2009, 07:22 AM   #122
gabanyayaya
I understand what you meen now and No. You can not omit the pots just because you have a 15V tranny.
You still have to use them to trim the voltage.
/JZ
Old 17th January 2009, 08:09 AM   #123
mikesnowdon's Avatar
I'll take one please.
www.drugfreeworld.org
Old 17th January 2009, 08:29 AM   #124
gabanyayaya
/JZ
I see now.........just now you said the pot can be substitute by a resistor. What values??? Is there's any different using this resistor compared to trimpot in term of SQ...? Do you think using a resistor is an alternative way to complete the power supply section without using a multi meter/volt tester?
Old 17th January 2009, 08:54 AM   #125
Tripmaster's Avatar
Hi Gabanyayaya
You can use the following voltage calculator to help you determine the correct resistors
http://www.justblair.co.uk/lm317-vol...alculator.html
(A shameless plug for Blair's website)
Richard
Old 17th January 2009, 11:11 AM   #126
Originally posted by Tripmaster
Hi Gabanyayaya
Richard
Wow...this sure is helpful. Thanks Tripmaster. Funny though because I used to talk each other with Mr. Blair few months ago but not about chipamp but a speaker modding and I did what he told me about my speaker...
Old 17th January 2009, 11:43 AM   #127
Buy how about LM337? any calculation for this regulator?
Old 17th January 2009, 11:48 AM   #128
Tripmaster's Avatar
I think its the same, someone may know different
Old 19th January 2009, 07:47 PM   #129
Puffin is offline Puffin  United Kingdom
Can any of you geniuses out there (a few regular posters spring to mind) give me a definitive answer as to whether this board has any DC blocking on it.
I had a problem with mine at the weekend and when testing/playing with it, it blew an old speaker! A strange noise and then....phut!
Old 19th January 2009, 08:10 PM   #130
You have put the caps on the output?
That should take of most junk.
So it sounds like there is something else that is the cause..
Can we have a picture perhaps?
Lets start with that.. oh and also what poweramp are you using.?
/JZ
A Simple opamp question? Dxvideo Chip Amps 29 3rd April 2009 02:42 PM
SOAP - Simple OpAmp Pre zei Chip Amps 14 12th December 2007 03:15 AM
Looking for Simple 12V supply dual opamp for kid's project chipco3434 Chip Amps 26 16th March 2006 08:13 PM
Designing a simple tube opamp? bradd Tubes / Valves 1 26th October 2005 07:24 AM
Copyright ©1999-2017 diyAudio
