SOAP MKIII (Simple OpAmp Pre) With onboard PSU
Old 30th November 2008, 09:43 PM   #111
Puffin is offline Puffin  United Kingdom
I had assumed that the caps at C15 - C18 might have been to provide DC blocking. I assume I am wrong. If I add caps on the output, what values do you suggest.
Trippy. For safety purposes I wear thick gardening gloves and use just spent matches to solder with as my mum told me not to play with hot things as I might hurt myself. My PCB's look like burnt pizza.
Old 30th November 2008, 09:56 PM   #112
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Puffin, I have a PCB just like yours but with a slightly different topping, if you know what I mean?
They say you cant educate pork!
Anyway...where are all the other builders posts, its been three weeks since I built mine, I'm sure Zei will be keen to know how you are all getting on
Richard
Old 30th November 2008, 10:01 PM   #113
How do you find yours after 3 weeks, any significant burn-in differences?
Old 1st December 2008, 08:32 PM   #114
Tripmaster's Avatar
Puff meister
During the first week I used 2.2uf Vishay capacitors at positions C15 and C16 and a pair Icel MWR 4.7uf caps at C17 and C18 (as pictured in a previous post), The sound was OK but I felt the bass sounded a bit flabby.
The following weekend I purchased some rather nice AMPOHM 3.3uf polyprops at an Audio Jumble near Leatherhead. That evening I decided to de-soldered the old capacitors and replaced them with the AMPOHMS...What a difference! the bass became tight and deep, there appeared to be a higher level of detail I had not previously experienced. I then swapped the OPA2132PA for the LM4562...yet again a noticeable improvement.
I auditioned several opamps, the OPA2132PA (FET), OPA2134, AD826ANZ and LM4562.
I didn't like the AD826, the OPA213PA sounded nice and the OPA2132PA had a warm signature but lacking the crisp sparkle of the LM4562.
I am currently making some aluminium cases to house my Chipamp and SOAP-Pre, I will post a couple of pictures when completed.
Richard
Old 2nd December 2008, 07:52 AM   #115
Thanks for that.
Old 2nd December 2008, 08:13 AM   #116
Tripmaster's Avatar
Thanks for that.
You must be out of breath, I am
Old 10th January 2009, 03:13 AM   #117
Mush is offline Mush  United States
Mush's Avatar
Default Alternative to Black Gate N/NX for SOAP
Hi Everyone,
I am having trouble finding 4.7uf N/NX Black Gates for coupling. The AMPOHM 3.3uf sounds great but I'm in the US. Does anyone know a source for the Black Gates or AMPOHM in the States or a good alternative cap for the SOAP mkIII that's availabe here?
Thanks for all of your posts. It's been very educational.
Ciao -- M
Old 10th January 2009, 03:38 AM   #118
troystg is offline troystg  United States
troystg's Avatar
Did you have a board left, and if so how much with shipping the the US?
After seeing and reading about it I think I have talked myself into one of these...
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 17th January 2009, 12:41 AM   #119
gabanyayaya is offline gabanyayaya  Malaysia
Originally posted by zei
I,m not shure what (if any) benefits there would be running an OpAmp at lower voltage (Within the recommended range of course)
Most of the times all this info is in the datascheet but i think that the only reason that they can take a range of different voltages is that it increases the numbers of applications they can be used in.
If i remember correctly the E5532 max voltage is +-22V
Opa2134 has a max V of -+18V
lets hope someone else has something more intteresting to say about this
I say +- 15V because it is a number No other reason
/JZ
zei,
If I'm using a 15V tranny would it be possible to remove the trimpot????
Do I have to adjust the voltage if decided to keep the pot?
Old 17th January 2009, 02:42 AM   #120
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Are these still available? If there's another buy I want one!!
It wouldn't be a big deal to integrate it with a dantimax remote control unit I'm assuming.
Wherever you go there you are.
SOAP MKIII (Simple OpAmp Pre) With onboard PSUHide this!Advertise here!
A Simple opamp question? Dxvideo Chip Amps 29 3rd April 2009 02:42 PM
SOAP - Simple OpAmp Pre zei Chip Amps 14 12th December 2007 03:15 AM
Looking for Simple 12V supply dual opamp for kid's project chipco3434 Chip Amps 26 16th March 2006 08:13 PM
Designing a simple tube opamp? bradd Tubes / Valves 1 26th October 2005 07:24 AM
