Looking for basic TDA7293 PCB and Parts list!!
Old 1st May 2008, 04:08 AM   #11
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Do check the maximum voltage tolerance of those pins. They do require a resistor.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 1st May 2008, 11:28 AM   #12
teemuk is offline teemuk  Finland
"On both the pins, the maximum applicable range corresponds to the operating supply voltage."
...and absolute Maximum ratings:
"VS Supply Voltage (No Signal) 60V"
"Mute Voltage Referred to -VS 120V"
"Stand-by Voltage Referred to -VS 120V"
So, the pins do not neccessarily require a resistor and I've seen plenty of circuits without one. But I agree, those are a good addition, along with some "delaying" capacitors. At the point when one decides to add these he might just as well upgrade to the suggested sequencing RC circuit. It's just two more components.
Old 3rd May 2008, 02:39 AM   #13
Minion is offline Minion  Canada
Hi, Here"s just an update ,I etched a PCB based on the Datasheet PCB with a few mods....It worked the first time I fired it up ,It has a very small amount of hum but no more than some systems I have heard....
Anyways Thanx guys....
Looking for basic TDA7293 PCB and Parts list!!Hide this!Advertise here!
F5 Parts List enzedone Pass Labs 2 22nd August 2008 12:15 AM
ESP P-101 parts list jeffshort2000 Solid State 2 27th August 2007 02:08 PM
Mullard 5-20 parts list Rob11966 Tubes / Valves 11 15th June 2007 10:36 AM
Could you check my parts list? maurycy Chip Amps 7 28th February 2006 06:01 AM
