| Chip Amps Amplifiers based on integrated circuits |
#321 |
5pin XLR?
regards Andrew T. |
#322 |
Thanks a lot for your replies. Now that I know the terminology will be much easier to find what I have in mind.
Yes I'm planning to do an unregulated snubberized PSU (ala Carlosfm) but with one rectifier bridge and one transformer per channel without common ground like this http://myweb.tiscali.co.uk/nuukspot/...cpsu.2t.2r.gif I will take care to include the separate switching and the ground leads, including an earth safety ground as suggested. Regards Antonio |
#323 | |
P.S. The power ground is the voltage reference point for your speaker. Take care to make it strong so that you have good bass. |
#324 | |
P.S. The metal shell of a commercial 1-piece bridge rectifier, is designed to be grounded, therefore it can go inside the same chassis as commercial broadcast equipment, thereby eliminating the noises caused by excess cable lengths. The noises are from rectifiers, not transformers. Here's some more ways to quiet the rectifier. . . See also: http://www.diyaudio.com/forums/showt...00#post1500500 See photo #4 here: http://diyaudioprojects.com/Chip/Syn...lone/index.htm And, have a look at other amplifier builds to see that the heatsink is often used as a shield/divider between power and amplifier. |
#325 |
Opinion:
I'm not in favor of seperate, external, boxes for power supplies. That extends the length of the cable, and personally, I'm against paying more to make extra noise. . . unless its a very decorative noise indeed. |
#326 |
Daniel,
I want to have the PSUs in a separate box for practical and WAF reasons. The WAF reasons is that there is no room so pile up more boxes where I have the hifi system and so I need to have it discretely placed on the floor on one side. The practical reason is that I want to start trying different chipamp configurations/chips and it is handy to not have to deal with transformers and bridges and electrical cables every time I want to make trials of new amps. Having a separate box with XLR connectors will allow me to plug and play/test new designs quick and easily. I hope I do not put too much noise doing this and I have seen many pros also do it. Antonio |
#327 | |
I'm so glad that you're doing this for practical reasons. But, I wanted to make it clear, that a single enclosure can perform quite well, and that seperate boxes aren't an audio enhancement. Seperate boxes are, in fact. . . only boxes. Its about time to start that power supply thread, isn't it? |
#328 | |
Antonio |
#329 |
Okay. That will be just as soon as I make something really nice to plug into that power supply.
Its been slowly forming here: http://www.diyaudio.com/forums/showt...85#post1514985 That's LM1875, now up to a 30w per channel, and it doesn't have the Spike system--so the typical chipamp clipping isn't present. I've been going slowly so that it looks pretty and do-able. The input circuit gets put on today. Wish me luck at keeping it good looking. |
#330 | |
| Complete beginner - Need Help | Metalcore322 | Solid State | 3 | 31st March 2009 03:52 PM |
| Complete beginner; looking to start. | kartoffel | Solid State | 4 | 11th October 2004 08:20 AM |
| Page generated in 0.11850 seconds (82.04% PHP - 17.96% MySQL) with 11 queries |
