Commercial complete Gainclone kit for a beginner?
Old 16th May 2008, 09:02 AM   #301
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Antonio, your experience is precisely why I recommend P2P for building chip amps.
With P2P, you see exactly where the wires go, and a quick check will usually reveal any errors. When you use a board, the connections are on one side and the components on the other so it is much harder to visually inspect that everything is where it should be and connected properly.
You shouldn't have damaged anything when you took it apart although only you know how much heat you applied, and for how long it was applied.
If you did reverse the connections from the rectifier, it is likely that you will have damaged the polarised caps. Do they show any signs of bulging?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 16th May 2008, 09:13 AM   #302
is this yet another case of starting up a new or modified project without a mains light bulb in the transformer's primary feed?
regards Andrew T.
Old 16th May 2008, 09:27 AM   #303
A Sanchez is offline A Sanchez  United States
Nuuk,
I did not explain myself well. I have used a plain perforated board so in fact the new build is also p2p and I can clearly see how and where everything is connected
The caps does not show any sign of burning.
AndrewT,
I did not perform the light bulb test the second time but the rectifier board was built separately and I did not touch it between the first successful attempt and the unsuccessful one. I did test the bridge with the did tester and everything seemed ok.
Nevertheless, I will do the light bulb test as suggested.
Thanks for your help.
Antonio
Ps Any answer to the question of whether the chip can be tested with a multimeter and how?
Old 16th May 2008, 09:39 AM   #304
Nuuk,
I used the rectifier as shown here:
http://dogbreath.de/Chipamps/GainCar...nCardCopy.html
I notice that in the rectifier the V+ and V- are really mirror images and it seems that that it would not matter connecting them either way to the chip.
On the other hand the caps where connected correctly in terms of polarity and chip pins.
Anyway I will start all over again as I am surely missing something.
Antonio
Old 16th May 2008, 09:46 AM   #305
Nuuk's Avatar
As far as I know, there is no way to test the chip with a meter, other than to make sure that there are no shorts between any of the pins (unless there are meant to be as is the case with the LM3886 with pins 1 and 5).
Old 16th May 2008, 10:04 AM   #306
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Hi Antonio.
It matters. Try a 1 piece rectifier (clearly marked, like KBPC1004), or have a look at this PDF: http://electronics123.net/amazon/datasheet/k114.pdf
See the polarity of the rectifier?
MUR860's? Oh heck! Well, have a look at this picture.
Old 16th May 2008, 05:49 PM   #307
Bluto is offline Bluto  United States
Default RE: Post # 302
Good point and I think a link to that ought to be in any instructions.
Bluto
Old 17th May 2008, 03:45 AM   #308
Default Re: RE: Post # 302
Bluto
That's ironic, in a way. Today, I was de-soldering MUR860's to replace them with quiet, 1 piece, commercial block rectifier.
Old 17th May 2008, 10:27 AM   #309
Originally posted by danielwritesbac
Hi Antonio.
Dan,
Many thanks for your comments.
My local supplier sells the KPBC rectifiers but not the KPBC1004. Here is the list of what they have: http://www.maplin.co.uk/Module.aspx?..._list_35_AQ98G
Could you tell me if I can use another model?
Are KBPC one piece rectifiers as good as building the rectifier with MUR680s, whcih what everyone seem to recommend?
Antonio
Old 17th May 2008, 10:48 AM   #310
Are .... one piece rectifiers as good as building the rectifier with MUR680s, whcih what everyone seem to recommend?
no,
not everyone recommends.
Many builders use the normal commercial rectifier bridges available in ratings from 1A to 35A.
regards Andrew T.
Commercial complete Gainclone kit for a beginner?Hide this!Advertise here!
Complete beginner - Need Help Metalcore322 Solid State 3 31st March 2009 04:52 PM
Complete beginner; looking to start. kartoffel Solid State 4 11th October 2004 09:20 AM
