| Chip Amps Amplifiers based on integrated circuits |
good day to all i'm just new here at this forum and i just like to ask a question or any idea. What amp should be good to use for a 18" super scooper? help help pls... thanks
#2 |
What duty? to suit PA, Disco, home, Partying?
What power? What speaker impedance?
regards Andrew T. |
#3 |
its just for patying use and its a 18" inch diameter at 8 ohms and i don't know about the impedance,and i just want simple,affordable yet powerful amp thanks man,i would just ask a favor for the amp details so i could start thanks and more pwer to diy'ers
#4 |
We now know it's for home use and partying and it's 8ohm.
Give us some more clues. 10W or 100W or 1000W?
regards Andrew T. |
#5 |
Honestly, a power amp for PA use (lots of watts) you would spend more building one than you would just to buy one. The heatsink, transformer and case alone would cost a lot, and then a whole lot more for good (real) output transistors.
#6 |
Perhaps a Class-D subwoofer amplifier for the woofers, as part of an "active" system?
Here's a short list of some sub amps: http://www.partsexpress.com/webpage....ctGroup_ID=505 On this type of amplifier, the power is given as if you have a 4 ohm load, so they will produce roughly half as much on an 8 ohm load. Its not a defect--that's just advertisement stuff. Also, check out products for "Prosound," "PA," and "DJ," in your local market. Those are the products that produce the nightclub sound. |
| Is the Super Scooper the same as the normal scoop bass bin | Bull | Multi-Way | 1 | 23rd February 2003 11:13 PM |
| Page generated in 0.07289 seconds (75.98% PHP - 24.02% MySQL) with 10 queries |
