| Chip Amps Amplifiers based on integrated circuits |
I am looking for some experiences with 4780 running on +-40V (2x30VAC) toroid. I am aware of the datasheet supply voltage limits, just could use some real life experience. The idea is to get close to 100W RMS out regardless of the load, in parallel config.
#2 |
Electrons are yellow and more is better!
If you can choose, choose 2 x 24-25VAC and max 2 x 28 VAC. You won't get many dB's extra risking the IC. 2 x 30VAC will produce 44-45 VDC and the marginal is zero. the difference between 50 W and 100 W is only 3 dB which is not much. If 50 W is too little you must go to 150-200 W at least in order to perceive any difference.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
True, but I don't think I will get as much as 44-45VDC with 30VAC. I am running 25VAC now and getting 34,4VDC out. Assuming the same losses and filtering setup with 30VAC, I should get around 41VDC.
#4 |
If if put my professional hat on I'd say: 2 x 24-25 VAC if you want to use LM4780. If you want substantially more power, look for a discrete power amp like Lynx or paX.
#5 |
you are getting 34.4Vdc from 25Vac. What is the mains input voltage? What is the mains tolerance? What is the ripple on the PSU? What is the maximum output voltage taking account of ripple? What is the range of voltages from your existing PSU for the full range of input voltages and output loadings? Now, redo the calculations for a 30Vac transformer but include regulation and tolerance as well as loading. In the UK using 5% regulation and 6% tolerance I reckon the maximum voltage from 30Vac is ~46.7Vdc. If the transformer is specified as 30Vac from 230Vac then the output is even higher.
regards Andrew T. |
#6 |
Good point Andrew.
#7 |
Hi Peranders,
If one cannot, or will not, follow all those stages in checking design output voltages of a simple PSU then the designer is incompetent.
regards Andrew T. |
#8 |
Incompetent, maybe so but this is DIY, a different thing. Some people don't want to listen to facts.
#9 | |
Incompetent DIY is = Incompetent DIY and that is completely different to DIY.
regards Andrew T. |
#10 |
I think we must create a sticky thread called:
"2 x 25V toroidal for 8 ohm loads 2 x 20V toroidal for 4 ohm loads (2 x 18V is more common) You could get by with 2 x 22V for both loads" Oh yes. and, "50 watts is actually MUCH louder than you think"
| P3A on +/-12V rails | 00940 | Solid State | 6 | 5th March 2008 12:44 PM |
| Split Rails off 5V USB | gbyleveldt | Digital Source | 4 | 9th October 2007 02:06 AM |
| LM4780 4ohm @ +/-40V rails | alexcd | Chip Amps | 14 | 13th December 2006 04:27 PM |
| from +/-80v to +/-70v rails | leander | Solid State | 14 | 13th September 2005 11:26 AM |
| Cap across rails? | MikeW | Pass Labs | 12 | 24th August 2004 01:35 PM |
| Page generated in 0.10790 seconds (77.71% PHP - 22.29% MySQL) with 10 queries |
