| Chip Amps Amplifiers based on integrated circuits |
2 quick questions.
I got a good deal on some 15000 uf caps and was wondering if I had to change the snubber values for carlos's design if I were to use these larger caps (seems everyone is using 10000) and I was wondering if I could use the following circuit from elliott's site for a buffer (with R3 and R4 removed for 0 gain) I got a couple of opa2134's laying around and not much in the way of discrete stuff for a buffer. |
#2 |
I'll leave the snubber question to a snubber fan, but I guess the 15K's would be fine.
As regards the buffer circuit, if you want a gain of 0, just leave the whole circuit out and don't connect anything in its place! What you mean is that you want no gain, ie a gain of 1, and that is what that circuit will give you, as will the buffer circuits shown here .
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 | |
Electrons are yellow and more is better!
More to read here
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
what is R5L feeding? This is a very high output impedance for feeding most circuits. The circuit has a gain of 2times (+6db). Add an RF filter after the 1k0 input resistor. And take that ground connection back to the input connector. It is part of the flow and return circuit for the input signal.
regards Andrew T. |
| couple of questions | slogan2112 | Multi-Way | 0 | 27th June 2004 08:38 PM |
| a couple questions | slackerbob | Solid State | 1 | 12th August 2003 02:25 AM |
| Page generated in 0.07494 seconds (75.18% PHP - 24.82% MySQL) with 11 queries |
