Old 22nd April 2008, 02:03 AM   #1
cryo is offline cryo  United States
Default gainclone power supply regulation
I am breadboarding up the power supply for my new amp. I happen to have a couple of nice small toroids (100va) which would be great to use. They put out 36-0-36, which when rectified might be a bit much.
Any objections to using a voltage regulator like the lm317 to bring the voltage into a tamer range?
Would it be best to place the regulator(s) before or after the bridge?
Any specific schematics that anyone can suggest?
Thanks for any help, and for all of the great info on this site.
Old 22nd April 2008, 02:58 AM   #2
Daveze is offline Daveze  Australia
My biggest concern would be how you get the required current out of your regulator...a single 317 might give you a few 1-2A if you treat it with care but you'll need a few in parallel to get what you really want. And when you're all finished, you'll probably only achieve ~60VA out of your 100VA transformers (the rest being burned off by the 317's).
Put your sets of primaries in series? That should cut your secondary voltages in half...
Signature Pending...
Old 22nd April 2008, 03:18 PM   #3
Thanks Daveze, I didn't realize I would lose so much using a regulator like the lm317. The thought of putting the primaries in series is a novel idea. I will try that out in the shop this weekend and see what I can come up with.
Old 22nd April 2008, 05:17 PM   #4
Minion is offline Minion  Canada
You can use a pass transistor with a LM317/337 regulator to increase it"s output current to 4 Amps+ ...The LM317 datasheet should show you how it is done...
I did this with a 10w Class A amp I built a while ago and it worked very well and only needed a couple power resistors and a power transistor....
Cheers
Old 23rd April 2008, 09:44 AM   #5
putting the primaries in series will reduce the input voltage by 50%. That will reduce the VA by 50%.
You still end up with 100VA for the pair.
Instead build a discrete amp that operates from +-50Vdc.
Old 23rd April 2008, 01:43 PM   #6
Oops. I got a little caught up in my nifty idea and forgot about what the consequences of halving the voltage would be...
I was also thinking the discrete amp option too, though I'd be thinking you have the gainclone as the amp...some sort of preamp might in order?
Old 23rd April 2008, 02:56 PM   #7
Thanks everyone for your ideas. Sounds like I need to pop for a new transformer for my gainclone. Then I will keep the 100va toroids for a new project, I think a pre-amp sounds like a logical next project.
gainclone power supply student Chip Amps 49 21st July 2010 09:38 PM
gainclone OFFSET regulation LS output sigurd Chip Amps 2 21st July 2009 09:23 AM
Gainclone Power Supply iandrum Power Supplies 11 28th January 2009 02:23 PM
SET Power Supply Regulation serengetiplains Tubes / Valves 33 18th May 2004 11:12 PM
Gainclone power supply soundNERD Chip Amps 10 4th February 2004 01:31 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
