Old 21st April 2008, 11:12 AM   #11
kanifee is offline kanifee  United Kingdom
I was planning on using my pc as the preamp for now, i do hope to build a preamp in the very near future with the active crossovers built into the power amp later on.
I have been told that this is the way to get the best from your setup, power amp, preamp and activ x-overs and run the speakers streight from the amp without there passive ones.
Id like to build the preamp from a kit or if im feeling a little braver from scratch maybe point to pont?
have you gto any good suggestions, oh and my speakers have 6 ohm tweeters and 8 ohm mid drivers, im not to fussed about bigger sinks ill sort them out not a problem, so id proberbly like to go with t he larger of the two transformers!
Old 21st April 2008, 06:21 PM   #12
danielwritesbac's Avatar
Have you any good suggestions. . .
A USB DAC with preamp!
That suggestion is because even the expensive computer sound cards may have crummy op amps aboard. It makes good sense to build your own so you can choose quality output from your computer.
There's also TDA1524A chip, which is a voltage-based bass-n-treble control + preamp unit. It doesn't run your signal through the control pots or against an RC, as it is higher-class voltage based preamp, like a RIIA amp. Anyway, its clearer than a software eq.
Its my own personal definition of transparency, that it is clarity without distraction.
This is the cause of my recommendation of a USB DAC (clarity) and a frequency response set in favor of the ear (without distraction).
I can't help on the active crossover idea because I haven't, personally, used a large enough sample of them for comparison (no baseline). See the loudspeaker forum for a good "head start" on that topic.
Tools & GuidesClipNipper headroom boostParallel LM1875 pt2ptEasy parallel TDA7293 boardTDA7294 pt2pt ♦ My post has opinion.
Old 21st April 2008, 06:26 PM   #13
TDA1524A chip <--- so this would take care of my bass and treble control in my preamp and then i would need a stereo pot for volume control in the pre amp or something else? i am a little noobish still so mind my lack of knowladge on pre amps, i only really just found out they even existed when i started this project never mind what they were for.
And then a usb dac to take care of the audio instead of the sound card or in conjuction with? never used a usb dac before!
Old 21st April 2008, 06:37 PM   #14
Kanifee.
If you want to read up on why chipamps may need a buffer or preamp try (as always) Decibel Dungeon.
http://myweb.tiscali.co.uk/nuukspot/...nclonepre.html
I'm using the "Uno" active pre with my LM3875. It can be done on stripboard but has no tone controls, I'm more than happy with it.
Have a browse through the site as there's a wealth of info on there.
Good luck
John
Old 21st April 2008, 07:20 PM   #15
The USB DAC is instead of the sound card.
D.A.C. = Digital to Analog Converter.
It solves the problem in getting your music out of your PC intact, so a USB DAC doesn't utilize a sound card within the audio chain (thereby making a USB DAC useful).
A reliable source is www.audiosector.com (scroll down the page until you reach the "latest news" section, with mention of the USB DAC).
See http://www.diyaudio.com/forums/showt...983#post603983 for more information.
Old 21st April 2008, 09:53 PM   #16
dfdye is offline dfdye  United States
dfdye's Avatar
Not to ruin the party, or to suggest that you shouldn't build a preamp if you want, but I am running a LM3886 dual monoblock amp straight out of my soundcard at my office, and it sounds fantastic. I have decent on-board sound card on my computer, and the limit of the system is definitely my speakers. Unless you already have a super spiffy pair of speakers, I would save the $$$ you would plunk down on a preamp and save for new drivers.
I know you are wanting to run an actively crossed over system, and I would highly recommend waiting until you decide on what type of crossovers you want to use before you start mucking around with preamps. Reason being, you will want to make sure that your preamp is capable of driving the potential multitude of inputs you may or may not decide to use with your active xover when the time comes. I, personally, would put a buffer in front of each active xover channel when building the xovers, obviating the "need" for a preamp.
Just food for thought. There certainly are a multitude of chipamp based systems running straight off of the soundcard line outs of computers, so PLEASE, don't think a preamp is a necessity.
Old 21st April 2008, 10:48 PM   #17
Its a very large and confusing world the land of DIY audio lol!
Im not to sure what direction im wanting to take this project in, im a bit of a tart when it comes to things though so my initial thoughts were high end audio setup, nice bulky solid power-amp with active xovers with a high end audio look, matching pre amp with bass, treble, input selection and volume controls with some sort of DIY dac for at minimum digital coax.
Im even putting thought to stripping out a ps1 and putting it in a matching case for a cd unit but id like a display really so i think that would be out of the question unless i go uber diy high end and fit an lcd screen for on screen music selection, so next would be a retail cd player gutted and fitted to a matching case, that is of course me just getting ahead fo my self.
I see your point on maybe putting a little aside for better speakers, my eltax monitors arnt the greatest so a pair of speakers would have a great impact on the overall quality of the rig. Im allready looking into "High-performance" mods i can make to the stock lm3886 but this will all be after testing etc;
Im trying to take onboard everything im wreading but its like info overload!
Old 21st April 2008, 11:31 PM   #18
Im not to sure what direction im wanting to take this project in, im a bit of a tart when it comes to things though so my initial thoughts were high end audio setup. . .
Well, you might take a little break to research active crossovers. This implies (to me) that there is one power amp module per each driver. It doesn't seem like you're headed in that particular direction at this time.
On the current project:
I wasn't aware that you are going high end. So, here's, a bit of consideration to dynamics. For example, on a stereo layout (one transformer), when a demand is made by the left channel, the power also drops for the right channel. However, a dual mono setup (two power supplies, two transformers) doesn't do that, so the dual-mono is capable of more dynamics.
The issue is unimportant for quiet, relaxing, listening; however, its a necessary consideration if you enjoy exuberance.
Old 21st April 2008, 11:58 PM   #19
dfdye's Avatar
No kidding!
Remember, if you are on a limited budget, your highest impact item will ALWAYS be your drivers! Most chip-amps are quite capable of cleanly driving speakers at moderate levels, so don't get too caught up in trying to tweak your amp too much. Daniel will (and has) suggested every esoteric tweak imaginable, so taking him with a grain of salt is highly recommended.
If you are looking for a good primer on active crossed speakers, you would be well served to check out Siegfreid Linkwitz's website where he documents his highly regarded active speakers. He also throws in a recommendation for an LM3886 circuit that I rather like, and contrary to Daniel's instance, Linkwitz uses ONE power supply for all of the 8 amplifier chips in his active system--I would dare anyone to suggest that Linkwitz's designs aren't "high end" or "exuberant."
Just so that there is no misunderstanding here: dual power supplies are NOT necessary for a very good amplifier. There is, of course, an argument for dual mono-block amplifiers, but pragmatically, you must decide whether the very subtle reduction in
Old 22nd April 2008, 04:14 AM   #20
This is most certainly true.
And, here I thought I was "playing it safe" but, of course, any mention of options does have a problem of its own.
Perhaps I should have asked more throughly about the application.
Well, here's a start:
Are your tastes more towards classical or popular?
Do you like your music moderate or loud?
Do you store your music inside the computer to use its automated playlist features, or do you store your music on CD?
And, please add a short description of what is satisfying about your current speakers and what isn't, as there "may" or "may not" be a suitable, specific, accomodation available.
Lastly, please describe your favorite place to listen to music, other than the home, and describe what is most endearing about that music.
The answers will better define the application.
And, given a narrower scope, I'd make a lot more sense. . . possibly.
FS:I/V transformer for DAC CHIP ANADIGIT Swap Meet 9 23rd January 2009 01:07 AM
which chip for my transformer dre Chip Amps 18 15th July 2008 05:27 PM
Stereo Chip Amp - one transformer or 2? groyne Chip Amps 12 18th May 2004 06:22 PM
Copyright ©1999-2013 diyAudio
