Old 13th April 2008, 11:49 AM   #1
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Cool lm4562 is cool!
i completed lm4562 preamp this weekend.i love it.
the attached is a photo of the real unit.i will post my pcb layout and sch file in a couple of days.
zang
Old 13th April 2008, 12:24 PM   #2
Tolu is offline Tolu  Germany
Tolu's Avatar
Hi Zang,
I love it, too.
I replaced the opamps (OPA2134) in my KR Audio Preamp with LM4562. It was an very audible improvement.
The "secret" for the use of LM4562 in a preamp is the following structure: input - 1st gain stage - pot - 2nd gain stage - output
The single use like pot + gain stage or buffer isn't satisfying (to my ears).
Old 14th April 2008, 03:26 AM   #3
digi01's Avatar
Hi Thomas,
Thank you for your ideaI will try it later.
the attached is my sch file.it is a DC amp.I keep it simple.
greetings from beijing,
Zang
Old 14th April 2008, 03:44 AM   #4
digi01's Avatar
The attached is my layout.
Consideration below:
1,the layout as compact as possible.
2,easy installation into a source or power amp.
3,smt & PDIP footprint.
4,simple power supply bypass.
5,big ground plate around opamp foot.
Old 15th April 2008, 06:57 PM   #5
Send a message via Yahoo to tobebu02
Hi Digi01,
Can you list the resistors & cap's values.
Thank you,
Old 16th April 2008, 12:49 AM   #6
digi01's Avatar
OK,
R1,3----------------1.2K
R2,4----------------100K
R5,6----------------39K
R7,8----------------415K
R9,10---------------12R
U1,2-----------------LM4562
C1,2,3,4,-----------35uf/25V
THE UNIT SHOULD RUN IN A BIT OF DAYS.
ZANG
Old 16th April 2008, 01:35 AM   #7
Thank you very much.
Regards.
Old 16th April 2008, 11:08 AM   #8
Hi Digi,
why run the signal through two stages of opamp?
Doing it the way you have will make conversion to Tolu's suggestion fairly easy.
Did you try a film or ceramic cap direct across V+ to V-? maybe 1uF
regards Andrew T.
Old 17th April 2008, 02:29 PM   #9
digi01's Avatar
because i want the preamp driving lowZ headphones.this capability is very useful at live playing.
example:when i play my yamaha keyboard,i want monitoring the playback via a headphone.and the line out can work together.
as the datasheet shown,the lm4562 chip can drive complex loads,but it is no good for lowZ loading.so i do a circuit bending.
i have try a film cap direct across V+ to V- on some solid amp that is good.i will try it on this preamp later,thank you!
zang
LM4562 op-amp GB novec Group Buys 285 26th June 2011 03:17 PM
FS: LM4562 (18 pcs) theAnonymous1 Swap Meet 5 23rd May 2008 01:47 PM
Self on LM4562 sam9 Solid State 7 17th April 2007 02:11 AM
Page generated in 0.08770 seconds (75.37% PHP - 24.63% MySQL) with 11 queries
