Old 13th April 2008, 10:56 AM   #1
danielwritesbac's Avatar
Default TDA7294. . . help! ;)
Hi, I'm making a circuit board for the TDA7294. . . in barely over an inch of space. The question is about the mute and standby circuits and what is the minimum support necessary to operate them.
ST mentions that they are two, seperate cmos operated switches. Okay.
On the bridge application chart, the ground returns for these two switches, pins 1 and 4, are shown jumpered together. That's half a clue.
The mute and standby, pins 10 and 9, do function if they are jumpered together. Now, the support can be providing them power with a single 10k resistor--eliminating a huge mess.
Despite that being undocumented, the amplifier has been running this way for 38 hours so far. There are no clicks, pops, burps, or noises at power on or power off.
Here's the question:
The amplifier "seems" to sound slightly different that way, than if two seperate resistors are used to feed power to pins 10 and 9. I can't measure that. Does anyone have any news on it?
Thanks!!
Old 13th April 2008, 05:24 PM   #2
It makes no difference. However, if you want to eliminate clicks and pops on startup/shutdown, you would ground the mute lead before turning amp on/off with the standby lead. You don't have to run them apart though. Connecting them together, and powering them at the same time is fine.
Old 14th April 2008, 07:14 AM   #3
It makes no difference? Oh, that's good news. So the slight audible difference that I observed between these two can be assumed to be an audible difference of the power circuit (removal of RC networks from the power circuit)--and not caused by the mute and standby switches themselves?
How do you like this circuit then?
Edit: its for double-sided PCB
Old 19th April 2008, 06:58 AM   #4
Hey, did you guys know that this thing gladly does 100 watts?
I gave it a 4 ohm load, and, welll!!
LM3886 vs TDA7294 Tobruk Chip Amps 57 22nd April 2011 09:50 AM
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
Page generated in 0.07323 seconds (75.37% PHP - 24.63% MySQL) with 11 queries
