Old 11th April 2008, 05:42 PM   #1
Tripmaster's Avatar
Default What a doofus!
Hello again
Whilst soldering two of the diodes I found the solder did not bond with the PCB (dirty contact). I ended up by applying too much heat to the board and have ended up damaging the copper pad.
Can I carefully solder this diode on the component side? Or is there a way of repairing the contact.
Tripmaster
Old 11th April 2008, 05:48 PM   #2
Tripmaster's Avatar
Here are some other photos
Old 11th April 2008, 06:24 PM   #3
49 - for the 16th time
c2cthomas's Avatar
Hello Tripmaster - you are looking for a circuit repair kit that is somewhat like this - http://cgi.ebay.com/PACE-CIR-KIT-Pri...QQcmdZViewItem
This kit is for repairing circuit traces as well as plated through holes and from reading your description I think the only thing you will need is the eyelet repair part of the kit. The one listed is in USA so you are most likely better off looking for something in GB - (although the dollar is low). Take a look at the photo's in this ad and you will see one of them that shows an eyelet being set into a PWB. Not difficult with the proper tools and a gentle touch. Hope this helps
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 11th April 2008, 06:49 PM   #4
Puffin is offline Puffin  United Kingdom
Tripmaster. I have one of these Chipamp.com boards. If you look at the track to which the diode is attached, you will see that the diode above it (on your photo, and next to the board edge), one leg is connected to the same track. Just solder a wire from the (right, according to your photo) leg and the right leg of the diode above. That leg of the diode will not be attached to the board,but it will still work.
Alternatively just scrape away some of the lacquer on the track to expose the copper track and connect a piece of wire from the exposed track to the leg.
Where in Hampshire are you ?
Old 11th April 2008, 09:19 PM   #5
Tripmaster's Avatar
Hayling Island, Nr Portsmouth
Old 12th April 2008, 06:43 AM   #6
Tripmaster. I am about 30 mins up the A3. If you can't get it sorted, perhaps we can get together ?
Old 12th April 2008, 06:55 AM   #7
Tripmaster's Avatar
Yes, why not.
Do you live near Petersfield?
Old 12th April 2008, 09:32 AM   #8
The other side of Haslemere.
Here is what I suggest you try
http://i73.photobucket.com/albums/i2...sex/ChipBD.jpg
Old 12th April 2008, 10:39 AM   #9
Tripmaster's Avatar
Thanks Puffin
Should I use the same wire that I plan to connect the PSU to the amps? I think it's 0.4mm
What have you used for your enclosure? I have two 300va 2x25 transformers
Old 12th April 2008, 10:50 AM   #10
is that 230:25+25Vac or 240:25+25Vac?
You are getting very close to maximum ratings for 8ohm speakers.
What is the maximum PSU voltage when the mains is @ 254Vac? i.e. +6% tolerance.
regards Andrew T.
doofus rotary switch selection question leebob Chip Amps 5 13th December 2007 02:53 AM
Page generated in 0.09922 seconds (78.70% PHP - 21.30% MySQL) with 11 queries
