| Chip Amps Amplifiers based on integrated circuits |
#71 |
look up the datasheet and see what load impedance will suit 20Vac (~28Vdc).
240VA is not a problem, it just uses up valuable resources that may be better elsewhere. 240VA could power 80W + 80W |
#72 |
#73 |
Looks great
Good work!
#74 | |
#75 |
I see two reasons. There may be others.
1.) The transformer regulation is too high for small transformers. 2.) The very small transformers don't sound as good. I suspect these two reasons are interlinked and come from massive variations in the PSU voltage as the current sent to the load varies. |
#76 |
Thanks man!
I was recently involved in (got roped into) making an extremely small amplifier with a 28VA transformer. This deal sounded rather good, but didn't have much bass. Comparing a very similar design using a 160VA transformer, well that amp on the big transfo doesn't lack for bass. Personally, I never found a substitute for a big linear supply; but, Surely there's some more elegant options than using a great big transformer every time? |
#77 | ||
#78 | |
#79 |
#80 |
Furthermore, can this preamp be used to drive three of these LM1875 PCBs?
Left/right full tone PCBs and a third LM1875 PCB to provide the low? Kinda like a sub-satelite computer speaker set with more balls? ![]() Also, I'm more interested in DIY at home my own PCBs so if you know of a preamp with basic tone control and volume that I can fabricate with free pcb layouts etc I would be very happy. DIY to me means I should be able to make my own PCBs and NOT have to purchase them, though I don't think purchasing PCBs is a bad thing for most if not all people. |
| LM1875...how low can you go? | Gcollier | Chip Amps | 7 | 6th May 2010 03:43 AM |
| How hot does an LM1875 get? | Dominique | Chip Amps | 15 | 23rd January 2007 02:13 AM |
| lm1875 | siemensc65 | Chip Amps | 4 | 23rd May 2006 03:28 AM |
| Lm1875 | soundNERD | Chip Amps | 14 | 12th October 2003 02:26 AM |
